Results 1 to 4 of 4
Thread: apec wheeel fit..
    VZ SV6
    Jul 2010
    Default apec wheeel fit..
    how yous goin
    i wanted to buy a set of wheel.
    and i was just wondering if 20" Apec racing wheels will fit my vz commodore sv6.
    the sizes are 20x8 +35mm offset Tyres are 245/35R20
    or if they dont fit, cant they be machine or re drilled to fit..
    thats as much info i could get sorry
    cheers
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    commodore offset is +45 i think..i might be wrong but im pretty sure it is...to determine if they need to be bored out to fit you will need to find out the centre bore measurement of the wheel...usually aftermarket wheels will have hub rings as they are designed to fit different models etc, so more then likely the bore will be slightly bigger and you will put hub rings on to compensate...cheers mate
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    Bored or just wanna talk about cars? Add me on facebook and we can talk
    http://www.facebook.com/#!/profile.php?id=1002697869
    VZ SV6
    Jul 2010
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    245/35 will probs rub on the strut.
  1. APEC wheels ??
    By simon-t in forum General
    Last Post: 26-07-2010, 10:11 PM
  2. [VIC] 18" Apec Apache rims and tyres suit VE
    By redvess in forum Parts And Other Items For Sale
    Last Post: 12-09-2009, 01:16 AM
