vz speedo stops working
ok i have a problem with my dash it was working fine and now has this thing it does once you hit a certain speed it stops working and returns to 0 even tho you are still increasing in speed including the digital speedo. so what is causing this to happen i changed the diff to 3.9 and the speedo got recalabrated but that is off the gear box. the rest of the dials work. any one else had this problem. also has anyone else get gremlins turn up when it rains?
Experience is a hard teacher. First you get the test, then you get the lesson.
