Results 1 to 4 of 4
Thread: Sticky rear window - VZ wagon
    '07 VZ Acclaim wagon.
    Sep 2010
    Mulgrave, VIC.
    Default Sticky rear window - VZ wagon
    Sup.
    Bought a VZ wagon, and I take delivery of it sometime this week. One issue that's gonna bug me, is the rear driver's side window is a bit sticky.
    When it's going down, it's slow until it's about half way down, then goes at normal speed. Same thing going up, but in reverse. It'll be fine until it hits about half way, then slows down quite a bit and slowly creeps up. Meanwhile the window motor is groaning a bit.
    Ideas? Just gotta pop the door trim off and check all the seals and whatnot, make sure nothing is dragging? Any particular type of lube better than others for this type of problem?
    Thanks, ladies and gentlemen.
    VE Calais, VL SL
    Mar 2009
    Adelaide Hill's
    I lubricate my power windows with a shiteload of graphite powder every so often, keeps them smooth as silk.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Make sure the rubber seal hasnt folded over on itself in the window track. Also make sure the window reg isnt bent out of shape or fouling on anything.
    Silicon lube in the tracks works well but may attract dirt..
    Silver Certified.
    Sep 2010
    Mulgrave, VIC.
    I've been told both of the above, graphite powder and the silicon lube.
    I might try the graphite powder in the tracks first, to keep it dry and not attract any dirt. If that doesn't work, I'll give the silicon stuff a go.
    Thanks gentlemen.
  1. How to fix the rear window wiper in a wagon
    By Cindam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2011, 09:50 AM
  2. VZ wagon rear window washer
    By Tnarg78 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-04-2010, 11:01 AM
  3. Wagon rear window wiper
    By keza87 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-02-2010, 07:47 AM
  4. wagon rear window rusting
    By adaml1754 in forum General
    Last Post: 18-05-2008, 10:13 PM
  5. How to install a rear wagon window???
    By Mick Molloy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2005, 12:46 PM
