Results 1 to 6 of 6
Thread: why wont the service remidner reset
    VZ SV6
    Oct 2008
    Newcastle NSW
    Default why wont the service remidner reset
    as the title says...... it gets to the "awaiting confirmation" screen however holding the Set button doesn't do anything... or any other combination of buttons.... (75k service, VZ SV6)
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    i think when the screen says service reset, hold the set button then
    Spoken by a true member of The Committee
    VZ Commodore Wagon and EH holden
    Sep 2010
    nowra
    some times they will not reset if the car has a code set in the computer, that way it makes you go to the dealership to get it fixed. But most likely it could be a problem with your buttons. The other way to reset them is with a tech 2 at the holden dealership. Just to make sure, you hold down the 2 arrows and turn on the ignition, the car will beep, then push and hold the set button, it will then beep again to let you know it has been cleared. Hope this helps
    VZ SV6
    Oct 2008
    Newcastle NSW
    Yeah rabs that's the method i'm using... I think there might be a code stored actually that could be on the money.... ta....
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    VL
    Jul 2009
    1 press and hold the 2 arrows
    2 turn the ignition on
    3 wait for a beep
    4 then press set (it will beep again)
    5 then press and hold the arrows again
  1. Service Reminder Reset
    By jvh in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-08-2010, 10:05 AM
  2. Can you reset the service reminder before due service interval?
    By redlion05 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-07-2010, 12:20 AM
  3. Service reset
    By dinodog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2010, 03:35 PM
  4. reset service
    By glowworm in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-06-2009, 09:26 AM
  5. How to reset the service reminder on a VT
    By Davo VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2006, 12:59 PM
