Results 1 to 13 of 13
Thread: ssl and exhaust problem?
    VZ SV6
    Jul 2010
    Default ssl and exhaust problem?
    i heard if i go king spring ssl with monroe gt shocks, and get a catback, that the exhaust will scrape and cause alot of hassle.
    has anybody had any experience with the two together..and would anyone know it would be a problem
    cheers
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Most if not all superlow cars have scraping problems with exhausts, especially over speed humps.
    Its one of the things you learn to live with when you want super low appearence.
    You could try getting a custom made exhaust and have them fit it as high, close to the floor as possible but that will cost you more than an off the shelf system.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    If you have exhaust fitted as close as possible to the floor then unlike a standard fitting you will have problems caused by heat - if you don't install heat-shields. Besides, lowering the suspension and fitting a loud/modified exhaust is a guaranteed way of attracting Police attention.
    VZ SV6
    Jul 2010
    hmm fair enough.. i know its cop bait. do you guys know if ssl is illegal? in victoria
    Dz811's Avatar
    Dz811 is offline Just some p-plater
    VZ SV6 M6
    Sep 2009
    VZ SV6
    Jul 2010
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    well your car would have fe2 suspension, holdens standard lower suspension
    Spoken by a true member of The Committee
    VZ SV6
    Jul 2010
    yeah it has fe2 as stock standard. does anyone kno how low in mm's ssl would lower my car
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Super Lows are 40-50mm below std, so ssl will be 50mm+
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Dz811's Avatar
    VZ SV6 M6
    Sep 2009
    and just to clarify, 50+mm below standard will almost certainly be illegal
    Quote Originally Posted by QuickVRII95 View Post
    I Outsmart Defence Force Psychologists... My IQ "IS" Also Over 165.....
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    VZ Calais
    Jul 2009
    That is very low!!! I have Lovells superlows and Boge lowered shocks and have scraped on 1 big speedhump in about 12 months... It is low, but not so low that I have to crab-walk over humps and thru dips. I think I'm about 20-25mm below FE2, just as a comparison...
    vz sv6
    Nov 2009
    isnt the rule of thumb 100mm under loweest part of car? or a coke can? myns not getting either hgaha
    VZ Calais
    Jul 2009
    In SA, its min 100mm at the lowest point (i think mudflaps are exempt) but there's also the 'eyebrow' height between the middle of the wheel and the bottom of the guard which is different for every make and model of car
  1. Exhaust Problem
    By hfcmad in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-01-2010, 02:29 PM
  2. odd exhaust problem
    By rob drag racer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-06-2009, 03:40 PM
  3. exhaust problem
    By flyen in forum V8 Development and Modification
    Last Post: 20-01-2008, 12:06 PM
  4. Exhaust Problem.
    By SoulGrind in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-02-2007, 02:47 PM
  5. Exhaust Problem
    By Dragz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2006, 06:34 PM
