I know I am just new but I was looking for some help with my Crewman, I have spent awhile searching the net for how to disable the traction control. I know the traction control is hardwired in and that disabling it will normally void the manufactures warranty. I have found 2 likely fix's but I am unsure if they are for the VZ Crewman or just the VZ Commodore.
One of the fix's states you should unplug the ABS plug and push out pin #27. I couldn't find a 27 or even a second plug.
Another fix was getting it flash tuned.
Which method is correct, and if the first is correct would I be able to cut wire 27, and bridge it with a switch that id locate in the cabin?
Additional Info: 2006 Holden Crewman 6 speed manual, 3.6ltr alloytec, S Pack, dual cab.
