Results 1 to 2 of 2
Thread: SV6 Engine and electrics cut-out
    VZ SV6
    Oct 2010
    perth
    Unhappy SV6 Engine and electrics cut-out
    PLEASE HELP!!!!
    I have stock standard VZ SV6, only 50,000k's, female driver only and it cuts out in the morning. It will sometimes require a couple of cranks to start, but then idles and runs fine, until a minute or two, or a few hundred metres it just dies - complete cut out, no engine, no electrics - when driving. Slip the car into neutral or park, re-start, and it is fine for the rest of the day.
    This started last summer, we had it at Holden for weeks on end over 10 visits and they could never "repeat" the fault - even though it happened most mornings, before 9am only - once there is some heat in the day it is fine..... Through the last winter the fault went away and we thought it had been rectified, but it happened for the first time again this morning - nice day, bit of sunshine at 8:30am.....
    I assume it is a condensation on a sensor problem, or some other weather variant issue - the car is parked outside overnight. Can someone please help - it is dangerous to drive....
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    I cant say I have ever had the problem myself, but it did happen on my friends VE SS. All I did for that was hit most of the plugs with some silicon spray and make sure the O2 sensor was plugged in properly.
    I am sure someone else can give a better solution though
  1. Electrics in VZ SV6
    By Ryley in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-07-2010, 03:46 PM
  2. [VS V6] intermittent electrics and engine cutout during fog
    By nathanVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2010, 04:28 PM
  3. Electrics help please
    By holden_calais_VT_1999 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-02-2010, 10:46 PM
  4. UHOH!!!!! Engine Bay electrics Prob
    By lgnd3800 in forum Electrical Wiring / Questions
    Last Post: 30-01-2008, 08:53 PM
  5. Need help electrics
    By herkman in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-02-2007, 08:09 AM
