Results 1 to 10 of 10
Thread: boost
    VZ SV6
    Jul 2010
    Mandurah
    Default boost
    hey guy im going to the local drag stip on wednesday and want to get the best possible time i can and jsut wondering if i put octane boost in my tank will it affect my engine in anyway cuz i am un aware if it will or not
    IF YOU WANNA REV IT CHEV IT
    2005 VZ SV6
    Apr 2010
    i put it in mine every 3 weeks or so and it works fine, goes abit harder as well...
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    I have used the pro boost in mine countless times. All it really seems to do is make it idle smoother and seems to make the fuel go down faster.
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    abg
    abg is offline
    05 VZ v6
    Oct 2009
    If you're after higher octane than whats commercially avaliable from a pump you'd be better off getting a hold of a drum of ethanol or toluene and tuning to suit. They both have octane ratings in the 110 range.
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    It may decrease your time....... as your car may knock due to the octane boost if it's not tuned to run it. Run what fuel your cars been tuned for.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    Dz811's Avatar
    Dz811 is offline Just some p-plater
    VZ SV6 M6
    Sep 2009
    Quote Originally Posted by bigdaddycool View Post
    correct... and incorrect...
    your car won't knock if you increase the octane, but it can if you DECREASE it (not that you would anyways).
    but correct that it won't do anything for you. Most tests show a decrease in power unless you specifically tune your car for the higher octane rating. Mainly because the chemicals ever so slightly (like half a percent) reduce the combustion energy in exchange for a much cleaner faster burn (which is what the octane rating represents).
    and before everyone goes correcting me, ok i might not know the exact terms etc used, but that's the basic gist of it
    Quote Originally Posted by QuickVRII95 View Post
    I Outsmart Defence Force Psychologists... My IQ "IS" Also Over 165.....
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    abg
    abg is offline
    05 VZ v6
    Oct 2009
    I'm really sorry to interject here, and I'm not in anyway having a go at you, I just want to help the community learn. Your pretty spot on but I'd just like to add a few more points:
    The octane rating is directly related to how hard it is to ignite the fuel, the higher the number, the harder it is to start it burning. A higher octane fuel is less likely to spontaneous ignite in an uncontrolled manner on it's own, in other words it's less likely to knock. Octane dosen't relate to energy content, a litre of 91 and a litre of 98 will release almost exactly the same amount of energy when burnt. Octane rating is related to how fast a fuel burns, the higher the rating the slower the burn. This is why you need to advance the ignition timing with higher octane to get more power. Peak torque is made when the combustion chamber pressure reaches it's maximum level at a specific non changing point in the pistons downstroke (from memory it's around 20-30 dgrees ATDC but I could be way off there). In order to get the pressure peak at this same sweet spot in the pistons cycle with a slower burning fuel (i.e. higher octane fuel) the burn must be started earlier (i.e. the ignition must be advanced). If the ignition timing isn't advanced and everything else is left the same then some energy is lost as the pressure peak occurs too late in the cycle.
    I'm really sorry to nerd it up here, and again absolutely nothing personal is intended, I just think it helps everyone understand why things happen the way they do when they know some of the background principles.
    Dz811's Avatar
    VZ SV6 M6
    Sep 2009
    Quote Originally Posted by abg View Post
    that's what i meant :P haha thanks man
  1. [WA] Wanted: Boost gauge,boost controller, ev6 36lb injectors and walbro in-tank
    By H1GHROLLR in forum Swap / Wanted to Buy / Trade
    Last Post: 11-06-2010, 04:42 PM
  2. On-Boost
    By QWiK747 in forum General
    Last Post: 06-10-2008, 09:57 PM
  3. Boost
    By wagonb0y in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-10-2006, 09:57 PM
  4. Boost
    By jetspin_vn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-11-2003, 03:15 PM
