Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Thread: when i throttle its very slugish!
    VZ v6 Executive alloytech 04
    May 2010
    Default when i throttle its very slugish!
    hi all
    when i put the throttle down it seems really slugish i dunno what this can be iv just had a service and no different,would it be the injectors,chuck in some injector cleaner or what else could it be
    cheers
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    by slugish what do you mean?
    do you mean it lags like when you put ur foot down it takes a little bit to respond?
    Spoken by a true member of The Committee
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    May 2010
    yeah ur right richard thats exactly what it does..mines 04 175kw alloytech as u probally would guess!
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by db_notso View Post
    whats the model of car?
    vz by the looks of his ride status
    injection cleaner could be a start.
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    May 2010
    yeah vz obviously thought that would of been clear on this post lol yeah that all use suggest!
    May 2009
    Gold Coast
    na nothing you can do buddy, its got to do with the electronic throttle. mines like that and every other vz will be too. im not sure if a tune can fix it though, but i wouldnt be worried, its normal.
    May 2010
    thats shit never use to be that sluggish,what if ya got a chip mod that would help! i wanta do some mods to it anyways so it might help once i figure out whats worth doing to it,cheers guys!
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    okay vz sluggis accleration (ignoring the "others" cause i knew you watching post and im lazy )
    is there an engine light on?
    is your air filter blocked? (can you see through it if you hold it up too light?)
    is the engine misfiring?
    can you hear any wiered noises around your motor?
    well start here at the basics huh?
    May 2010
    yes theres a whistling sound coming from engine,i have a cold air intake on mine just new,( keep in mind none of this happened after i installed this iv had it in for ages and had no problem) no engine light and no misfiring air filter is clear and clean!
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    okay
    take your intake off your throttle body turn ignition on and hold accel pedal flat does the throttle plate move too fully open (some year models you have to be very quick)
    May 2010
    which is throttle body that where it enters the engine? sorry it sounds stupid i only know lil bout cars and am picking things up sorry!
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    yeah where it enters the engine on the front metal part of your intake.
    take your intake pipe off here
    May 2010
  15. #15
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    ign on
    intake off
    pedal full throttle
    the "butterfly" or disc inside should move to horizontal or as little restriction as possible
    after this check we move to but not in this order!~
    fuel preasures, blocked exhaust or restricted intake tube, incorrectly fitted maf sensr (wrong way around has arrow on it), dtc checks, compression checks
  16. #16
    May 2009
    Gold Coast
    Gas Peddel Lag
    this may be worth reading regarding the lag issue
  17. #17
    May 2009
    Gold Coast
    ign on
    intake off
    pedal full throttle
    you may need someone to step on the pedal while you look at it
  18. #18
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    adjusting the internals on pedals from different models will normaly end up wtih o no linear movement of the butterfly e.g. not smooth
    would be better getting a wreckers one than adjust this screw think of it as a mixture screw!~
    i told him to wedge the pedal p higher too that info for the pedal adjustment would be good for fitting fly by wire to a cable tyoe car but...
  19. #19
    May 2009
    Gold Coast
    lol na not the actual fix, but more that he is not the only one with this prob.
  20. #20
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    oh i get it its unsolved soz man !~ is pretty common problem im surprised none of yas have sorted it normally ends up being fuel pressure or vacum leaks or intake blocked
  21. #21
    May 2009
    Gold Coast
  22. #22
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
  23. #23
    May 2009
    Gold Coast
    haha, righto man, enjoi. if anyone every finds a solution to it that would be awesome
  24. #24
    May 2010
    hmm il check maf but i sure i put that on correctly il have to pull throttle body one of tomorrow as im not ment to work on my car in my units where i live gay strata lol,the maf is the air sensor yeah? determines to computer how much fuel to mix etc? just making sure i ant a dummy lol just not a pro,with the butterly valve,what am i looking for in it if its sticking or somethen?
  25. #25
    May 2010
    just seen this on ebay...BBK COMMODORE LS1 VT VX VY VZ VORTECH CNC THROTTLE BODY...direct bolt in is it worth upgrading the throttle body? whats the instake size on the standard stock throttle body?
  1. vr ss slugish
    By ssvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-09-2010, 08:20 PM
  2. Vp Running Slugish?
    By VPplayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-08-2010, 02:36 PM
  3. slugish
    By bulldog79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 11:16 PM
  4. Car slugish
    By Matt83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-12-2009, 10:46 AM
  5. VT slugish
    By arty in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-06-2008, 09:28 PM
