hi all
Just wondering what the difference is between the ls1 engines in vt, vx, vy, vz. I have a vz ss and im in need for a new engine. Would the earlier model engines suit if i change the throttle body over???
going on what ive heard from people who have worked on and owned various ls1 engines i would stick with a gen III engine and onwards.
ive known a couple of people with vt-vx engines with a bunch of problems.
this is all heresay though. but i spose all info helps.
better getting the latest you can find but vz are electronic throttle so better off sticking with a vy one
go for an ls7
L98 FTW![]()
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
You could probably pickup a VZ l76 brand new which would be alot easier to fit as the later VE L76/98 have a lot of physical and electronic dofferences to the VZ.
The VZ LS1 5.7 uses an electronic throttle body so changing to a VZ L76 6.0 might be fairly straight forward, although not exactly sure of what the PCM difference between the VZ engines are.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
I have a VZ LS! Monaro & the donk is quite different to the WH Caprice I had in 2001. The donk has been refined quite a lot with better heads , pistons & rings, inlet manifolds , exhaust manifolds , computer, water pump, A/C compressor, to name a few . Power is up to 260kw from 220kw back in 2001 version.
The later models had better power down low (the early ones suffered badly with "Doughy" performance unless there was 4000rpm on the tacho.
Stick to a 2005 or later 5.7. The 6.0 litres & above have different PCU & would be hard to assimilate into a VZ. You can put 6.0 litre heads straight on to a 5.7 (cathedral inlet type) for an extra 20kw too.
