Results 1 to 7 of 7
Thread: Need suggestions on OTR cold air intake systems.
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    Default Need suggestions on OTR cold air intake systems.
    I have been looking around the net for a good Over The Radiator (OTR) cold air intake system for my VZ Crewman ute. And all of them look rather cheap, though in cost they are anything but. So I was thinking of making my own.
    My idea was to cut the opening into the stock radiator shroud, make a small ram and use ducting to link it near the original air box (so I can still use a high flow air-filter and keep it looking stock). I would then cover the ducting and air-box in aluminum heat tape to help keep the temperature down.
    Is this idea feasible or are there better options to doing this?
    Any suggestions or improvements.
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Suggetion: Don't Bother, all Alloytec OTR CAI look Crappy and dont really do a darn thing (except cost a lot) Save your coin and spend $30 on a M.C.A.I or two hole mod.
    Life starts at 200km/h
    eaton v8's Avatar
    eaton v8 is offline my little sleeper
    vz 6l auto 239cam 3.9diff
    Jun 2008
    gladstone qld
    Just get a dus Otr they almost look like they were put there from the factory. If you don't know what they look like I'll put up a photo tommoro
    Experience is a hard teacher. First you get the test, then you get the lesson.
    VZ Alloytec V6
    Nov 2010
    Tampa FL
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    otr wont fit, needs the maf, unless you can modify it, but then again Castle Hill have designed one, and did not get power gains, instead got a reduction in power from fitting the otr to the alloytec. dont believe me, call them up hope this helped.
    Spoken by a true member of The Committee
    VE SSV Ute - Series 2
    Sep 2010
    Would a VCM unit be suitable?
    They looks pretty sweet!
  1. normal air intake vs pod filter vs cold air intake: fuel economy
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 09:38 PM
  2. [VIC] cold air intake
    By bigazza in forum Parts And Other Items For Sale
    Last Post: 25-10-2009, 01:25 AM
  3. Cold air intake Help
    By holden_calais_VT_1999 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-09-2009, 06:57 PM
  4. Air intake systems
    By blowera1 in forum V6 Development And Modification
    Last Post: 04-06-2005, 03:07 PM
