Results 1 to 7 of 7
Thread: pedders ultra low
    vz v8 wanna be
    Sep 2010
    caloundra
    Default pedders ultra low
    hey guys, thinking of buying a pair of second hand pedders ultra lows with air assist . these are of a vz ute, and i am just wondering how these will sit on a sedan?
    will they sit higher than sedan ultra lows? or lower?
    also does any one see a problem with using these? ( under the assumption they they will fit )
    cheers
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    1. Yes, they will fit as such.
    2. They will sit higher, since they are from a ute, they will be stiffer than sedan springs for carrying loads.
    3. Only problem I forsee is the ride will be brutal in the back seat.
    Vy Sv8
    Jun 2009
    will most prop sit lower due to ute springs made for a lighter weight then a sedan
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Quote Originally Posted by M01ST View Post
    Err... what?
    I suggest you jump on redbook and check kerb weights. In the VZ an exec sedan is 30kg less than a ute and in the SS variants the sedan is 45kg heavier, true.
    But the ute is designed to take 650kg in the tray thus has stiffer, taller springs.
    vz v8 wanna be
    Sep 2010
    caloundra
    ok so how bad are we talking about ride wise? im also planning on keeping the same shocks, and will handling improve?
    ve sv6
    Aug 2010
    do you know what part number the coils are?if you do i can give you a rough height, most people put sedan coils (pedders) in there ute to get them lower so they will probably be ok, what the air assist? is it an airbag.
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Quote Originally Posted by trenooo View Post
    Original shocks?
    Have fun with that.
    Ride, How much do you like your spine the way it is?
    Handling, no.
  1. [VIC] Selling Pedders Ultra Low Springs!
    By Zep in forum Parts And Other Items For Sale
    Last Post: 16-02-2010, 08:09 PM
  2. my ultra lows arnt looking so "ultra low" why?
    By fergie_vs in forum General
    Last Post: 21-12-2009, 12:51 PM
  3. [VIC] Trading my Pedders Ultra low springs..
    By Zep in forum Swap / Wanted to Buy / Trade
    Last Post: 21-12-2009, 07:04 AM
  4. Pedders.....?
    By VNV6VENGEANCE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-08-2006, 01:06 PM
