Results 1 to 10 of 10
Thread: How to ensure the underbody of my VZ Doesn't rust?
    VZ Commodore SS
    May 2010
    Default How to ensure the underbody of my VZ Doesn't rust?
    I was driving through heavy rain today and came to a flooded salt water creak that was about 30-35cms deep across the road. As I was in very heavy traffic and had no where to turn around I had to drive through it. How can I ensure that it doesn't rust underneath? I have given it a good hose down 10-15mins underneath. Should this do? I don't have any cleaning equipment as I am visiting family. Thanks!!
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    take it to a local carwash and give it a good soaking like you have done...
    then id be getting a few cans of wd40 and go nuts spraying underneath in all the little nooks and crannies where the water could/would sit
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Yes, find a car wash with a jet spray under-body detergent wash/rinse. Salt water residue is hideous: it will damage the lower radiator grill, alloy rims, brake components, handbrake guides and capstans... the list goes on. Cars belong on dry land, not in the briney.
    The sooner the car is thoroughly rinsed, the better the outcome. Around where I live there are 4WDs that have been riding through the surf at Fraser Island and the ultra-expensive rims are finished; speckled, pitted and stained — the proverbial "point of no return".
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    VZ Executive
    Dec 2008
    Yeah as long as you give it a rinse and a good spray with WD-40 it will be fine! But as Little red VZ Go-Kart said I would give the Wheels a spray to!
    Couldn't be without my Commodore
    VZ Commodore SS
    May 2010
    I gave it a through spray underneath this arvo, I also gave the wheels a spray! I think I have unblocked a leak to that I have been looking for to :/ as there is a great big puddle of water under it! Will WD-40 do it? I was on to it with the water to rinse it out pretty quick!
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    VZ Commodore SS
    May 2010
    Is it ok to put WD-40 on the exhaust? I have already put it on it, as it has started to rust.....
    VZ Executive
    Dec 2008
    No WD-40 can be put on exhausts! I was at the Mechanics with my VZ Last week and the mechanics from Holden sprayed WD-40 all over the bottom of it including the exhaust to clean and protect it all whilst looking for a coolant leak. I use it on my Motor Bike exhaust and often clean the Exhaust of my Mazda 3 with it! Its just like degreezer but it seals and protects!
    Aug 2010
    The smell of WD-40 on a hot exhaust is ... bloody awful. Ditto applying the stuff anywhere air is not circulating. Lord, I thought my brother's bad breath was the pits until the little blue and yella can came along.
    Brushing extra virgin olive oil over metal offers protection too, minus the pong.
    VZ Executive
    Dec 2008
    Yes It does smell for a while but it dissolves pretty much straight away when the car is running!
  1. Underbody photo IRS VQ/VP
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2009, 01:23 AM
  2. where to buy underbody led kit
    By kru.vt97 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-10-2009, 12:32 AM
  3. Underbody of your car
    By M01ST in forum General
    Last Post: 25-06-2009, 06:20 PM
  4. Underbody Hot Wash
    By hjtrbo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2008, 06:48 PM
  5. dirty underbody
    By JB33 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-11-2008, 09:43 PM
