Results 1 to 8 of 8
Thread: alloytec problem
    2004 VZ Commodore
    Jul 2010
    Exclamation alloytec problem
    i was sitting at the lights and all the sudden the revs dropped all the whole car started shaking the engine got allot louder and fumes became more noticable, and when i drove off the car shook the more i put my foot down, i asked around and most people think that it will be a simple as changing a faulty spark plug, but i have no idea. what do you think?????????
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Fuel pump could be the first suspect.
    If engine continues shaking violently and hesitates when driving off (and requires progressively more and more revs just to try and stabilise the engine), the fuel pump is a strong suspect. Slowing down then produces a stall. Starting/re-starting will also be progressively more difficult (leading terminal) as a fuel pump dies.
    What you described is exactly the same as I experienced with my old Lexcen CSi V6. But alloytecs are a much more advanced engine than what I used to have. Nevertheless, a dead fuel pump
    trapped me 600km from home and necessitated a $1379 tilt-tray transfer back home, put a new pump in, that turned out to be faulty 500km later, so the car shaked, rattled and rumbled again... It cost a fortune (main reason car was jettisoned this July for a VZ!!). So check everything very, very carefully.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    i would look at the cheapest thing that may cause it like plugs and coils than to go straight to an expensive fuel pump.
    Spoken by a true member of The Committee
    Aug 2010
    Not that coils are cheap either, Richard!
    After a high pressure spray of the engine and a rough start then stalls, a coil pack set me back $400 two years ago... :
    I'm over it. Cars are bloody expensive things to keep going!
    May 2009
    Gold Coast
    Quote Originally Posted by Little Red VZ Go-Kart View Post
    ebay! or just buy one and swap them around until it fixes it, if of course its the problem.
    does it still shudder at high rpm?
    take it to a mech and get a diagnosis then fix it yourself.
    2004 VZ Commodore
    Jul 2010
    vz wagon
    Aug 2006
    Wild west of Melb
    Id have a guss at a coil as the fuems would be from runnin rich as not burnin fuel ya should be able to get it put on a scanner and ya mechanic or holden joint and that should tell you what has gone wrong holden is about 60 bucks the mechanic im about to start using in melb is 33 so alot cheaper and it gonna be easier in the long run to get it scanned b4 ya start throwin money at it.
    2004 VZ Commodore
    Jul 2010
    its actually running at 16.3l/100kms up from its usual 10.2l/100km since it started being crap
  1. Alloytec Owners: Who has the best sounding alloytec?
    By Owned in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-07-2010, 01:19 AM
  2. '04 vz alloytec lpg/petrol problem
    By mike0001 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-08-2009, 11:27 PM
  3. VE FI alloytec psi??
    By kuzman89 in forum VE Holden Commodore (2006 - ?)
    Last Post: 19-05-2009, 08:49 AM
  4. problem alloytec sports exhaust help
    By Breno in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-01-2009, 12:39 PM
  5. Alloytec and Alloytec 190 Engine Specs and Details
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2005, 05:24 PM
