does anybody know off aftermarket piston rings suppliers for a vz holden vz v6 3.6 alloytec
pls help if can
got a set from one supplier a hasting brand but end gap was too big wasnt right although i have standard bore i did get a refund from shop i still wonder if they suplied wrong rings
so if othesr have had this problem let me know how you resolved issue pls
Bit of a late reply I know but I thought I should post it anyway as it may help someone else out. LR ENGINE ASM-3.6L V6 PART 1 CYLINDER BLOCK & INTERNAL PARTS (LY7/3.6-7); LR,LS ENGINE ASM-3.6L V6 PART 1 CYLINDER BLOCK & INTERNAL PARTS (LY7/3.6-7);. Fits: Vue | Nalley Buick GMC Brunswick I'm pretty sure there the rings your after man
thanks for reply the rings mentioned above do fit pistons and right size gaps etc i tested one set on a alloytec pistion and inside std bore but second ring has a wider face touching bore than gmh australain rings for leo motors a reduced size face touching bore but same fitting size into pistion diesigned for less friction i guess okay if use all 6 in a motor and have even wear ..but just replacing one set may cause difference in wear over time
they be same as LY7 rings no doubt at all as ly7 and leo use same pistons
sorted out my getting my rings just get gmh or gm rings better fit than hastings i done a full rebiuld from mostly usa parts saved heeps in cost and enjoyed the research,,no way in the world could do a rebiuld in australian gmh part prices
