Results 1 to 13 of 13
Thread: Are Sedan door trims the same as a wagon?
    ruredi's Avatar
    ruredi is offline AVGJO3
    '02 VX II Berlina Station Wagon 5.7L
    Jul 2005
    Default Are Sedan door trims the same as a wagon?
    Hi guys,
    Are VZ Sedan door trims the same as a Wagon? Want to change the interior in my VZ Lumina Wagon but there isn't much out there for Wagons.
    Cheers, Joe
    Everything is possible for him who believes. Mark 9:23
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Check holmart.com.au; if I remember right they have door / window trims for VZ, among other models.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    yep both the same
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Every thing below the window level is the same size so you can swap door trims with any other VY/VZ door trims.
    I think VT/VX and VY/VZ door trims have different attachment methods.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    As far as I know they are all the same from the waist/window line down.
    The extra length of a wagon is the section behind the door not in the door itself.
    Have seen statesman door trims on sedans and statesmans and wagons share the same floorpan.
    Torquative's Avatar
    Jun 2005
    there ya go, learn something new every day!!! I always thought the extra length was in the door.
    Black VZ Wagon
    Apr 2008
    Brishole QLD. Hopefully Gold Coast soon
    ruredi's Avatar
    Jul 2005
    Thanks guys. If anyone knows where I can get a set of VY / VZ SS door trims, please let me know!
    Torquative's Avatar
    Jun 2005
    ah yeh fair enough, I had a closer look at the wagon today and yeh the door trims look to be the same, obviously everything else above it isnt (like the doors shape)
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Quote Originally Posted by Surfwagon View Post
    Incorrect. The measurement from the datum point on the rear of the front chassis rail to the the datum point on the front of the rear chassis rail is 1030mm for the sedan & 1180mm for the wagon, so the floorpans are not identical. As an aside, I also found this out the hard way on my old VN wagon, when trying to fit new carpet for a sedan into a wagon, that VN sedans & wagon have different floor pans (the sedan carpet was roughly 50mm or so too short. Doh )
    As for the doors, I would make absolutely sure that the sedans & wagon rear door trims are the same - even going to the point of actually measuring them.
    Just checked the factory measurements for the sedan & wagon rear doors and as I suspected, they are different. The wagon door is 10mm narrower at the upper datum points (999mm versus 989mm).
    Weekend Warrior above has probably summed it up correctly: the doors themselves are different, but the all the interior trims may possibly be the same. A few measurements, as I suggested, would confirm this.
    PS: Is anyone after a brand new VN factory sedan floor carpet? LOL Guaranteed not to fit a VN wagon (double LOL)
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by bcw61 View Post
    As for the doors, I would make absolutely sure that the sedans & wagon rear doors are the same - even going to the point of actually measuring them.
    thats why it was said from window down and he said the statesman shares the same floorpan as the wagon not a normal sedan and nothing about a vn.
    Sep 2009
    It was quoted 'Have seen statesman door trims on sedans and statesmans and wagons share the same floorpan.'
    I was merely pointing out that sedans & wagon do not share the same floorpan. You are correct that the Stateman shares the same dimensions, but the way it was written, it could be confused with the sedan as well. As for the VN reference, I was merely pointing out personal experience, with the difference between the sedan & wagon. That is why I referred to it as an aside - you must have missed that part.
    Just had a look & the Statesman rear door has different dimensions again, so the original statement that measurements need to be checked is valid.
  1. [SA] VT VX Wagon - exterior chrome window/ door trims
    By agrsv8 in forum Swap / Wanted to Buy / Trade
    Last Post: 22-04-2010, 03:22 PM
  2. will sedan door fit wagon vs
    By sycvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2009, 11:04 PM
  3. DO Sedan Door Cards Fit wagon doors?
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2009, 08:03 PM
  4. Are sedan,wagon and statesman door trims interchagable?
    By pjdm1980 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2009, 05:16 PM
  5. Rear door trim for wagon - sedan the same??
    By mad13b in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-01-2007, 08:58 PM
