gday all
was informed last night that i have light out on rear numberplate
as of this morning i went and had a look at the bulb hoping that was the issue but it appears to be fine
i had a quick flick through the manual but i can't find the fuse im looking for
does anyone else know where i should be looking to locate the source of the problem?
If you think the bulb (globe) is OK then start checking for poor connection(s)/earth etc. Fuse panel under dash (below steering).
dont you have 2 ligts over the number plate is only one out? if so put the working one in the spot where the non working one is before you go hunting for fuses
