Results 1 to 3 of 3
Thread: Badges lifting
    VE SS-V, V8, 6 Speed Manual
    Apr 2009
    Default Badges lifting
    hey guys,
    just have the Lion badge on the rear of my ute which is starting to detach\lift itself from the tailgate.
    i want to stick it back down on the side that has started to lift.
    just wondering if there is anything i should\shouldn't use to stick it down.
    cheers
    timmo
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Industrial-grade double sided tape (very thin) is standard on all badgework, and it's design property is such that it usually will not take paintwork off with it when removed. It has been affected by moisture then dust, causing loss of adhesion. As the original adhesive is now unserviceable that best option is to ditch the entire badge for a new one. Alternatively, remove the whole badge, then go over the rear to remove all traces of the old adhesive with metho or turps (metho usually works). Dry thoroughly, then apply a very thin line of Tarzan's Grip. Allow to become tacky, then press into place. If the badge is noticeably warped/bowed, this may not work. Don't use superglue as it runs and once it dribbles down onto the paintwork there is no recourse to removing it without damage.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    VS V6 Manual Wagon / VS V6 Manual Supercharged
    Oct 2010
    Just get a new badge from Holden, pretty sure the badge is around the $15 - 20. If you want a HSV there about $90. The only other way would be to take that badge off, clean all the tape off it and re tape it yourself.
  1. Car Lifting
    By nstone63 in forum General
    Last Post: 15-04-2010, 11:27 AM
  2. [VIC] WTT Chev badges for Holden badges VYSS
    By Galixia in forum Swap / Wanted to Buy / Trade
    Last Post: 09-04-2010, 07:03 PM
  3. clear lifting
    By vr1962 in forum Car Care Products
    Last Post: 29-11-2009, 09:18 PM
  4. Lifting Muffler
    By G4orce in forum General
    Last Post: 21-11-2007, 06:10 PM
  5. LIfting the rear of a Ute
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2005, 09:34 PM
