Results 1 to 5 of 5
Thread: Fitting new drivers seatbelt socket.VZ commodore
    VE SS Commodore
    Apr 2010
    Post Fitting new drivers seatbelt socket.VZ commodore
    Can anyone help me i am changing the seat belt socket on the drivers side of my VZ commodore and i was told it could set off the airbag. Does anyone know if that's true and what i can do to get around it?
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Quote Originally Posted by Bonza View Post
    The seat belt socket (receptacle) indeed contains the seat belt pre-tensioner assembly. If you don't have the correct instructions for replacing it and are not 100% confident working on the occupant protection system, I would strongly recommend leaving this job for an authorised dealer or mechanic.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Don't know exactly why you are changing the seat belt however, make sure that it complies with ADR's (Australian Design Regulations), should be stamped somewhere or have a tag fitted with specifics. To do otherwise will make your vehicle unroadworthy. p.s. don't use seconmdhand belt(s) as you have absolutely no idea what they may have been subjected to and could fail (for you) at a life threating time !!
    Any (ANY) modification(s), unless approved to ADR standards, that change/alter/modify any aspect of your vehicle from the ADR standards/requirements that existed at the time of manufacture of your vehicle are ILLEGAL.
    Phyco's Avatar
    Phyco is offline Alloytec and Proud
    06 VZ Acclaim Sedan
    Mar 2009
    WA
    Quote Originally Posted by Benboy View Post
    Do you have this ready to copy/paste? I see it in almost every thread you post in, and no-one cares!
    -My VZ Acclaim- feat. ASR Audio Sound/Lighting and Various Other Mods
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    If you've been told that you could set off the airbag, that's a heads-up worth noting, not likely heresy. It apparently isn't cheap to replace an airbag assembly (from how it was explained to me, once the airbags go off in the dash, that's it: all out and replace. Ditto the seat(s)) The SRS light that illuminates on the dash briefly when starting is a clue to interdependence of the seat belt assembly (all of it) with airbags, pretensioners and other safety features.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
  1. Fitting drivers flush?
    By Fun_Bucket in forum Car Audio
    Last Post: 03-01-2010, 02:49 AM
  2. Fitting Drivers Side Window
    By gee-aye-dee in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2009, 07:49 PM
  3. [SA] Wanted vn drivers side seatbelt
    By omaz78 in forum Swap / Wanted to Buy / Trade
    Last Post: 08-06-2009, 11:42 AM
  4. WTB: Rear Drivers Side Seatbelt
    By shaggerz in forum Swap / Wanted to Buy / Trade
    Last Post: 25-08-2007, 07:23 PM
  5. Fitting drivers side window
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2006, 01:34 PM
Tags for this Thread
