Results 1 to 3 of 3
Thread: Horn and Active select not working ????????HELP
    vz sv6
    Nov 2009
    Default Horn and Active select not working ????????HELP
    can anyone help me with this. the fuses are all fine. active select turns on but the paddles wont work and the horn will work when i lock the car but not when i push the horn
    2005 RED VZ SV6
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Maybe left field here (and probably way off the mark as usual LOL), but sounds suspiciously like a clock spring issue (working on the theory of a common point to both issues). Has there been any maintenance carried out around your steering wheel or steering column recently?
    vz sv6
    Nov 2009
    yes sicne the post i have been told that it is the clock spring. any ideas on a cheap place that does it?
    2005 RED VZ SV6
  1. [WA] Active Select - SV6 VZ
    By suga4oot in forum General
    Last Post: 15-09-2010, 07:42 PM
  2. Sv6 active select
    By richardpalinkas in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-07-2010, 08:19 PM
  3. active select shift
    By richardpalinkas in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2010, 09:33 PM
  4. Active select paddles not working
    By da_warped_1 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 31-03-2010, 12:08 PM
  5. VZ Adventra Active Select
    By AWD_VZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-11-2005, 09:41 PM
