Results 1 to 11 of 11
Thread: vz commodore light bulk for window blown
    vz commodore lumina
    Jan 2010
    sydney
    Default vz commodore light bulk for window blown
    hey every1 just need some help as the people at supercheap had no idea how to help . the light inside the window switch button on the back door blew, its a tiny bulb inside, does any1 no the size of this light?
    VZ Acclaim
    Jan 2010
    Brisbane,QLD
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    Thought they were LED's?
    Have you pulled apart the switch itself? If not, try clean out the terminals/connections of it, aparently they gum up with crap and thats what stops them working.
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Quote Originally Posted by vz23kq View Post
    Unfortunately, along with the headlamp switch and the trip computer switch, the side window switches are illuminated with filament bulbs, but the switches are sealed units and the bulbs are not serviceable.
    I have pulled apart an old VZ headlamp switch, and the bulbs are similar to the old 'grain of wheat' type, with a green plastic sleeve over them. They are soldered onto a PCB within the headlamp switch, and I think the trip computer switch and side window switches must have a similar setup. I suppose that you might be able to source new bulbs from a specialty electronics supplier, but I'd imagine that it would be a bugger of a job to replace them.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    /\ spot on. Holden's theory was (well I guess anyway) that little filaments will never blow! Every VZ I know has at least one of the switches out, being rear window or one of the globes on the headlight switch. If you can source one its not impossible to change, but definately a bugger.
    Might be easier just to buy a new switch from Holden, when I did it a few years back I think it was $30 or something.
    Sep 2009
    Quote Originally Posted by Torquative View Post
    If the OP (or anyone else for that matter) is interested, I have managed to source new globes. PM me for details.
    vy acclaim wagon s1
    Dec 2010
    teralba
    Default mickjh
    can u tell me where i can get hold of the bulbs for vy power windows
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    would it be possible to take the old bulb out and solder in a led?
    Best RPG ever
    '07 VZ Acclaim wagon.
    Sep 2010
    Mulgrave, VIC.
    The globes for the rear window switches are not soldered to a PCB, they are a actually like a little individual dash-globe.
    You could go to the effort of pulling the switch apart to get to it, but you need to figure out if it's worth the hassle. My window switch broke the other day, this is what it looks like on the inside. Oh, and a new switch is $82 from Holden...
    If you decide you want to change it, take the globe out and go to Jaycar or Repco, might be able to match something up.
    Need a part number? PM me.
    Luke.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Sep 2009
    Attached is a sample picture of some 12Volt 720mW bulbs that I have got. They are identical to the ones in the VZ headlight switch (I fitted one to be sure), and I assume they are the same as the power window switch - certainly look the same as the one in your pictures.
    The job of replacing the bulb is somewhat fiddly, but able to be done. On the headlight switch, the bulb fits into a plastic base, with the bulb connection leads fitting into slot in the holder. Once again, the power window switch should have a similar arrangement. You also need to ensure that you remove the little green plastic bulb cover (fits like a condom on the actual globe) from the old bulb and fit it to the new bulb. Just make sure you don't lose the sucker!!!
    PM me if you are still interested in getting a bulb or two.
    Attached Thumbnails Attached Thumbnails vz commodore light bulk for window blown-minature-12-volt-720mw-lamp.jpg
  1. Light Blown in Power Window Switch
    By wetwork65 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-11-2006, 07:57 PM
  2. Light Blown on Power Window Switch
    Last Post: 20-08-2006, 07:22 PM
  3. Top of selector/heat/fan light blown
    By Avi8or in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2006, 10:23 PM
  4. Under Gear Light Blown? how do i get to it?
    By orrdogg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2006, 10:22 PM
  5. park light fuse blown
    By DustyV8 in forum General
    Last Post: 03-05-2005, 01:37 PM
Tags for this Thread
