Results 1 to 7 of 7
Thread: How do i know if my coils are stuffed
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    Default How do i know if my coils are stuffed
    hey all,
    i've had a rough idle sicne i've bought my vz v6 ute...im pretty sure it has a minor misfire in there, i've checked the spark plugs and they're fine..had a look at the coils and down the inside barrel part there was some slight white powdery stuff on the sides, not were it contacts the spark plug, it wasn't corrosion though..i've had a look around and there's no resistance specified..so how do i know if my coils are buggered?
    cheers everyone
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    Bored or just wanna talk about cars? Add me on facebook and we can talk
    http://www.facebook.com/#!/profile.php?id=1002697869
    abg
    abg is offline
    05 VZ v6
    Oct 2009
    I think you'd get a error code for a misfire if that was your problem. Have you been in any other VZs? Alloytec engines don't like to idle smoothly at all, they shake the whole car.
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    That's news to me...
    I've had x2 dead fuel pumps shake my old car around, before that, one of the coils blew. Not sure that it can be said an Alloytec is not a smooth idler...
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    VZ Calais
    Jul 2009
    mine didnt throw any codes when i had a misfire. it could be a coil, could be bad fuel, a bad plug... if you have the lights on, that lowers the rpm and causes a vibration, same with radio and fan/aircon etc etc etc
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    my brothers vz calais idles perfectly, you could probably do the 50 cent coin test on top of that engine...mine will idle smoothish then it'd give the car a kick every now and then...fuel is always bp 95 or 98 octane...i've checked my plugs and they're burning as they should be...i just need to test my coils without replacing them to find out which one is buggered
    VZ Calais
    Jul 2009
    Buy 1 and rotate it thru all the different positions until the problem goes away
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    well that'd suck considering i'd have the keep takin the plenum on and off to do it right...im pretty sure its a vacuum leak anyways...between my inlet menifold and plenum..i ripped it a tiny bit before by accident...i realllyyyy hope its not valley gaskets though, i cant be arsed to do them hahaha
  1. [QLD] Wtb: L67 or v6 msd coils
    By na3point8 in forum Swap / Wanted to Buy / Trade
    Last Post: 21-07-2009, 07:08 PM
  2. FE2 coils
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-05-2009, 07:51 AM
  3. MSD coils
    By cruzncommo in forum The Pub
    Last Post: 25-02-2007, 09:38 PM
  4. MSD coils
    By veclubby in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2006, 09:14 PM
  5. difference between LS1 coils and LS2 coils
    By nos666 in forum Electrical Wiring / Questions
    Last Post: 29-03-2006, 11:28 AM
