Results 1 to 9 of 9
Thread: Alloytec with 3:46:1 Diff, Developing a mysterious squeaking noise!
    Owned's Avatar
    Owned is offline VZ SV6
    VZ SV6
    Aug 2009
    Default Alloytec with 3:46:1 Diff, Developing a mysterious squeaking noise!
    Hey guys,
    Ever since my Alloytec 190 made over 200rwhp I noticed a pretty loud squeak noise in between gear changes time to time especially when in pwr mode when it drops a gear and engages. Now that i have a 3:46:1 diff it happens more frequently. Does anyone know what this mysterious squeaking noise might be? Its really bugging me now, id like to get it fixed asap as it can also be quite embarrassing.
    If there is anyone experiencing or have had the same problem in the past id really appreciate it if you could help me.
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    i get squeeks, but i think its the clips that hold the rubber gromets on the exhaust hangers, you know the clips that stop the rubbers from falling off.
    Spoken by a true member of The Committee
    Owned's Avatar
    VZ SV6
    Aug 2009
    Quote Originally Posted by richardpalinkas View Post
    Yeh, but my squeek is a very, VERY loud squeek! i doubt it would be the clips that hold the rubber grommets on, it seems to be comming from the engine bay maybe? its hard to tell..
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    200rwkw... you have what turbo/supercharger setup?
    is the noise coming from the engine or diff?
    could be engine belt slip...
    Phyco's Avatar
    Phyco is offline Alloytec and Proud
    06 VZ Acclaim Sedan
    Mar 2009
    WA
    Quote Originally Posted by Owned View Post
    Any chance it is this same squeek? Download squeel.wav from Sendspace.com - send big files the easy way
    -My VZ Acclaim- feat. ASR Audio Sound/Lighting and Various Other Mods
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    i wish my car made an extra 60-70kw at the wheels haha, thats mad
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    Bored or just wanna talk about cars? Add me on facebook and we can talk
    http://www.facebook.com/#!/profile.php?id=1002697869
    Owned's Avatar
    VZ SV6
    Aug 2009
    Quote Originally Posted by impulsesv6 View Post
    I suspect that the loud squeek is coming from the front of the car, I doubt it could be the diff due to the fact the same noise was recurring with the factory diff before i swapped it for a 3.46:1 diff.
    If it was my engine belt slipping is there anything i can do to fix this, other than replacing it?
    Quote Originally Posted by Phyco View Post
    Hey mate, i had a listen but i could not hear a squeeking noise, id know if it was the same squeek because it happens whilst engaging the changed gear and its bloody LOUD.
    Quote Originally Posted by 2005vzute View Post
    haha my bad *over 200rwhp*, but 200rwkw would be very nice though .
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    haha yea man...with the belt, if you think it might be slipping, on your tensioner just check where the mark is to see if the belt is stretched a fair bit or not..if it is, replace it, or maybe your tensioner could be stuffed, might have lost tension...what i would do if i was you if grab some of that belt grip stuff from repco or somewhere..spray it on..if it stops you know its a belt/pulley...if it keeps going, its something else...if the noise does stop, replace the belt, if its on its last legs and you use belt grip, the belt grip stuff isn't good for your belt so i'd reckon to change it straight away...can you get a recording or something of your squeaking noise?
    Phyco's Avatar
    06 VZ Acclaim Sedan
    Mar 2009
    WA
    Sorry I should of mentioned it is around the 6-7 second mark, will try to highlight it a bit in the audio and re-upload if you like.
  1. squeaking noise in air con.
    By Northern_Union in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2011, 11:06 AM
  2. Squeaking/whistling noise
    By haboob in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-09-2010, 03:17 PM
  3. squeaking noise when in gear
    By nagles_18 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2009, 08:21 AM
  4. VS loud squeaking noise
    By jared_vn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-06-2009, 03:02 PM
  5. squeaking noise from the engine
    By race4life in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-11-2006, 12:43 PM
