Results 1 to 4 of 4
Thread: can the tension be adjusted on the accelerator pedal?
    VZ SS-Z
    May 2006
    Default can the tension be adjusted on the accelerator pedal?
    Hey guys,
    I've just bought a 2005 VZ SS-Z, and found the accelerator pedal a bit too hard. Is there a way the tension can be softened? All the VY's I've driven have a perfect setting, and I know the VZ uses an electronic throttle, but I'd prefer it to be more like the VY. Can it be done, if so, how?
    Thanks.
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Short answer... No.
    There is no actual cable connecting the pedal and the throttle/butterfly on the manifold, so unless there is an adjustment on the pedal itself that I am not aware of your a little stuck with it I think.
    DISCLAIMER: (I have been know to be worng, so seek a professional opinion...)
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    maybe you need to into it with some WD-40 or CRC.. could just be full of shit, so to speak
    Life starts at 200km/h
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    I think you can, if you go and buy an accelerator pedal assembly from the wreckers, open it up. You should find a coil like spring, just replace that with one that has less resistance.
    The procedure to do it is rather difficult. And honestly, dangerous, it is stiff for a reason. Loosening it up will increase the chances of the pedal getting stuck, especially during a full depression. But that is the way to adjust it so to speak.
    The reason for buying a second assembly is because it isn't easy to do, and the last thing you want to do is break your only one.
  1. 6 and V8 accelerator cable/pedal
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-11-2009, 02:07 PM
  2. accelerator pedal
    By 94calais in forum General
    Last Post: 21-11-2008, 09:52 PM
  3. Accelerator pedal differences
    By ozengines in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-09-2007, 10:46 AM
  4. VS Accelerator Pedal
    By KILLERVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2006, 07:26 PM
  5. How to remove Accelerator Pedal?? Anyone know how to...
    By t3zza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2004, 09:08 AM
