hi there
thinking of buying a v8 wagon and i have done a bit of research into it
what i am after is one with prefereably leather and more luxury options
it seems that ss wagons are only in vy's and that in vz's berlina has the leather and luxury bits
my question is, in wagon form with a v8, what are the differences between the series?
suspension geometry/linkages?
motor tweaks for more power/fuel consumption?
dash and interior trim?
and so on
any help or pointers in the right direction would be much appreciated!
thanks in advance!
Vy sereis 1 to 2 are mostly little things, one that comes to mind are the alloy tie down rails in the floor of the wagon, the engine is the same I think. In a VZ the V8 engine has a "fly by wire" throttle.
yea ve is a bit out of the budget lol
thanks for the quick reply wortus
hows the inside trim like?
does vy or vy s2 have digital climate control?
ah ok
going off redbook, berlina would be the top of line line available with a v8 and leather etc
vy and vy s2 had berlina and ss
in terms of suspension components and geometry are they similar?
i read somewhere that the vz had better linkages?
im more worried bout rear allignment adjustability from the factory such as toe, etc
also... i read that the vy/vy s2 wagons were 5 door but vz were classed/called 4 door wagons
what is the go with that?
thanks for the comments!
much appreciated!
climate control did came in the vy and vys2 ss wagons but its hard to found tho
