Results 1 to 8 of 8
Thread: Adventra Transfer Case/Front Diff problem
    Adventra SX6
    Jan 2010
    Default Adventra Transfer Case/Front Diff problem
    I've got a clunk in the drive train of my '05 Adventra SX6 with 160K on the clock. When the car is coasting to a stop there is a clunk in the drive train when the geabox changes down gears, also there is a lot of slack when I shift from P to D on the auto.
    I've taken the car to a mechanic I trust and had it checked over. The CV's, gearbox and rear diff were all fine, however he said the issue was in either the transfer case or the front diff.
    His solution was to ignore it and turn the stereo up.. because replacing the transfer case was going to be a few grand, and to work on the front diff you need to remove the engine !!!
    Has anyone else had a similar issue? What have you done about it?
    2006 SX6 Adventra
    Apr 2010
    Hi There.......Whats the verdict. I have an 06 V6 Adventra, and was curious of the outcome of yours.
    Adventra CX6 VZ, 2005
    Jan 2011
    I have had a similar issue for the last 3 years. I have taken it back to a holden dealer on a number of times and although they have found many things to replace/fix, they have never found this problem..... until hopefully now. I drove the car one morning and it started making a large clunking sound from the front of the car. It got towed and now they are telling me it is the transcase. Hopefully this will be covered under my extended waranty.
    For the last 3 years I kept saying to the holden service centre, I hope the car would just pack up so they could finally find this issue (the clunking when coming to a stop). Car has only done 90K km.
    Unfortunataly I love the car, the size, features etc and don't want to sell. It's just with all the problems it has had (mostly under waranty) I'm finding it hard to keep it.
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    my cx8 also does this shifting down from 4th to third.
    SIR LS1
    the two ton go kart
    2006 SX6 Adventra
    Apr 2010
    Update.......
    Well over the xmas period i took Le Wag in for the recommended Gearbox/ front and rear diff and transfer case and Power steering oil drain and change........
    Fellow Adevntra Owners.
    Do you know the 5l40E Gearbox is BMW ( thats where I bought my Gearbox service kit from as Genuine Holden want twice the price for it) and the Rear Diff is Ford? and the Transfer case is made by some little company California??
    VY Crewman Cross 8
    Mar 2011
    Hi, Do you know what the specs of the oil used in the transfer case was?
    Quote Originally Posted by Tim_in_NZ View Post
    Update.......
    wetwork65's Avatar
    wetwork65 is offline A wet business
    VY Berlina V8 & VZ Adventra LX8
    Mar 2006
    With the goblins in South West WA
    I bought the oil from Coventrys in WA. $20 for 250 ml. Only a piddle needed in the transfer case, but the old stuff was black as the proverbial. The spec is smelly - dunno the SAE rating and viscosity etc, not worth finding out really.
    2006 SX6 Adventra
    Apr 2010
    Hi there, the Transfer case oil is the only Genuine product that one has to use. Its tricky to get it in the transfer case and it only takes a bout a teaspoon in the end.
  1. VY Cross 8 Transfer case oil
    By tymes in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-02-2010, 01:39 PM
  2. Adventra Diff Rattle
    By SteveSX6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-10-2009, 09:39 PM
  3. vk 6cyl to v8 transfer
    By lance panther in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-04-2009, 04:58 PM
  4. front timing case seal
    By Galixia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-12-2008, 10:22 AM
Tags for this Thread
