hey
i few weeks ago i pulled my dash (plastic) off and painted it etc
well i got it back in then but my air con is playing up now? i have it set on face but it going threw the window...but if i turn the air con off and back on again it go's to face then when im driving and i pass 1.500rpm it cuts out back to the window
can anyone help me?? its doing my head in so bad
thanks
Check out my Svz
http://forums.justcommodores.com.au/...87-my-svz.html
maybe the flaps are closed on the dash part. double check it
i remember hearing of a thread a LONNNGGGG time ago, might not hurt searching back threads on this one, might come up trumps! Good Luck
Life starts at 200km/h
the white flaps at the back on dash inside car seem to shut when im cruising at 1,500rpm and don't open til i stop or idle. im goin to try the vaccum line at the back of manifold 2morow...hopefully it just that
Check out my Svz
There is a one way valve at the back of the manifold near the firewall that you can test.
If that's not the issue then it could be a vacuum leak if you haven't connected one of the actuators behind the dash (I think there are two of them).
all fixed. it was a vaccum hose in the engine bay under engine cover. thanks everyone for the input
Check out my Svz
