Results 1 to 8 of 8
Thread: correct tyre pressures
    VZ v6 Executive alloytech 04
    May 2010
    Default correct tyre pressures
    hi all, got 18 inch rims on my tyres just wondering what tyre pressure u reccomend for short distance driving less then 45 minutes each day roughly! use to drive to sydney and back from newcastle everyday but that has changed now!
    cheers
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Yes, 35 to 38psi would be a pretty good ballpark figure (CORSA C2233 235/45x17; 38 all around).
    Remember that the psi rate will go up as the car is driven at speed (to around 40-45psi), and that low profile tyres require a higher psi because of less volume. That's the risk with deep potholes.
    Inflate for conditions and as per tyre manufacturer. Higher pressures can give a slight improvement in fuel economy but correspondingly a little less grippy and of course, low profiles are very choppy, but still super-grippy.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    VX S S/C & BA XR6T
    Feb 2009
    VZ SV6 but have owned VC,VK,VL,VP,VT
    Sep 2009
    South East Queensland
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    your always going to get differing opinions, then it also depends on the brand/profile of the tyre.
    Personally I run mine at 38psi (cold) all round too, but it can really be anywhere from say 36 - 40 I guess
    dmar's Avatar
    dmar is offline kl
    vz
    Mar 2008
    i run 40 cause im paranoid about pot holes etc
  1. Tyre pressures
    By impulsive in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-01-2010, 08:34 AM
  2. Tyre pressures
    By satos in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-02-2009, 09:59 PM
  3. Correct Tyre Rotation
    By Brin in forum The Pub
    Last Post: 18-01-2009, 07:15 AM
  4. Tyre Pressures
    By Ronaldw in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-02-2008, 11:33 PM
  5. Tyre Pressures
    By thad 5l in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2007, 06:39 PM
