Hey all, got a problem with the coils, i went to auto electrician and on the dignostic it came up with coil 4 has got a problem, they wanted to change it but their going to charge me an insane amount, so i wanted to know which one is coil 4 so i can change it my self
Here you are, should help you:
thanks so much for that really appreciate it
What does the coil-on-plug assembly look like Benboy?
I'm interested in this. Not that I need to replace anything, just that I cannot see much without removing the inlet manifold!
•:*¨¨*:•.When you start your car, does it return the favour?•:*¨¨*:•.
Originally posted by soop
Your arse is going to sting for a while, and then worse when it does bugger all.![]()
They look like this.
