hey guys,
quick question for ya, now ive got the standard climate control in the car, and was thinkin about putting in the digital climate control?
now is this just a plug and play thing here? or is this just a massive head f**k?
thanks
Daniel
by standard climate control u mean the ones that are standard with executives and the likes?
if it is, then i think its a bit more complicated than just plaug and play, but could be wrong
yeh its been asked several times
Simple answer yes its possible, do you want to do it on a VZ? No ... Bear in mind these are based on people wanting to do it to lower end models such as Exec, SV6 etc, but the idea is the same .. if you currently have 3 round knobs for your AC and want to change it to the cool LCD digital panel on any VZ, then everything below is relevant
Standard climate controls to electronic, can it be done?
This comes up a lot, and the answer is basically that yes it can be done, but very few people do because of the cost and complexity. Aside from the controls/facia the heater box is different I think, you may need a new BCM, there are tons of sensor etc and for the marginal benefit that is climate control (esp. single zone) it's hard to justify doing it.Climate Control/Standard Heater A/C Controlyes the heater box it different, as the standard type uses vacuum solenoids to control temp and duct selection - the electronic control - not surprisingly - uses electric motor solenoids. You also need a different BCM, you need the climate control button panel obviously, you need a different centre console panel to accomodate the above control module, you'll probably need to buy the other console panels so they colour match with the new centre dash panel, you need an altogether different wiring harness, and you'll need to competely dismantle the dash to swap all the stuff over. It's a HUGE job, and would surely end up being VERY costly.
Fitting Binnacle Gauges/SS Aircon/Radio centre piece to SV6, ud need a level 3 dash loom and extra sensors, plus level 3 bcm, if that would even work in an exec
Fitting the auto CC, is as above, just very time consuming & expensive. I did consider it at one stage until i found out its not worth it.
retrofit climate control
Standard to electronic climate conversion VZAgree with above post, it's not worth it. There are sensors and shit yuou need to put in and fiddle with, all sorts of electronis and crap that need to be installed and modified to work, use the heater + window and do it the old fashioned way
upgrade to climate controlhey mate, i was researching this myself a while ago on the forum and it is just NOT worth doing it, youre gonna fork out alot of money and a BIG load of time! i was willing to pay anything for it as it would look better than the standard controls but in the end i realised its just not worth it
Climate control question
Hope this helps
thanks for the info m8, more then enough and made my mind up fairly quickly from reading it all...time and money will be spent better on other parts on the car id say![]()
lol no worries!
On earlier models like VS for example it wasnt quite so hard because it was more or less a matter of plug and play with some additional wiring and sensors, was still fiddly but possible ... but on VZ forget it unless your absolutely desperate for it.
yeh just kinda miss it frm my vx calais lol, meh
hey guys i know its the wrong place to post my question but i cant find another place atm.. i got a vz calais and everytime i hit the lock button on my key all the doors lock exept for the driver door and the horn beeps 5 times. i can lock it manually from the door but yeh. gets annoying after a while
anyone know what the problem might be and how much is it to fix?
thanks in advance
you could just start it as a new topic and ask the question ...
but it sounds like the door actuator has gone, the 5 beeps is to let you know there's a problem "and the cars not secure" which you know because the drivers doors not locked
lol i looked everywhere and i couldnt find a "post new thread" buttonmaybe im just way blind
could you please let me know how to do it for future reference?
and with the car.. i can lock all the doors so its secure. but yeh it just doesnt always lock by remote so i have to do it manually.
is there a thread for vr / vs aircon to climate upgrade?
G'day guys,
Not to e the one to open this topic again, but was there a VR -VS upgrade from Manual to Auto Climate control. I had it in my Senator but just bough a GTS and wanted to go back to it if it was possible.
Thanks for any assistance or pointing me in the right direction.
