wanta get good brand spark plugs and leads to improve me car what brands would u suggest for vz 175kw and how much am i loooking at
cheers
oh dear, good luck finding a set of leads for your VZ.
(Alloytec's don't need leads, the coils sit straight on the plugs !
And plugs won't make any difference, just replace with the standard ones, how many k's on your car ?
Plugs you'd be looking at roughly 20 bucks per plug. That's just off the top of my head though.
But yeah, VZs don't have leads, and you're not going to gain any noticeable difference from "High performance" plugs. Just stick to standard platinums.
Need a part number? PM me.
Luke.
got 175 thousand ks on it,just cant seem to work out what the hell this flat spot is been caused from,air intakes all fine just had a service done,cleaned out the throttle body im out of ideas i dunno why its so slugish!
is it an auto?maybe ur up for a transmission service
Make sure the vacuume pipe of the throttle body is not split and sucking air, that will give you a miss fire
Some plugs cost $60 each. Not sure what these are but said to have platinum and so-and-so with a life of 160,000km.
•:*¨¨*:•.When you start your car, does it return the favour?•:*¨¨*:•.
Originally posted by soop
Your arse is going to sting for a while, and then worse when it does bugger all.![]()
Dead spots in acceleration? Check your knock sensors and oxygen sensors. Maybe try an ECU reset (i.e. battery disconnect) also. Plugs should be changed at 100,000km intervals on petrol models and the best plugs to use are either double platinums or iridiums.
Injected CNG, LNG & LPG: The only way to go better!
i hope your not paying 20 bux for a plug, let alone 60 bux...i think 11-12 bux for the ngk iridums part number ltr6ap-11 from the top of me head, get them from anywhere, i'd say ngk would be the best, dunno why, its a personal thing, spark plug's a spark plug really, all they gotta do is spark and that's their job done.
Bored or just wanna talk about cars? Add me on facebook and we can talk
http://www.facebook.com/#!/profile.php?id=1002697869
I just use these & they work fine. Platinum's are changed every 120,000 kays.
Genuine Holden VZ V6 Commodore Spark Plugs x10 92067204 (eBay item 270657595781 end time 01-Dec-10 15:27:22 AEDST) : Cars, Bikes, Boats
