Results 1 to 3 of 3
Thread: Fuel Problem VZ
    VZ Berlina
    Jan 2009
    Maitland SA
    Default Fuel Problem VZ
    Well over the past few days the fuel gauge gives weird readings. Soon as you get to about half full the slights hill will send the gauge to empty. Would this mean the sender is stuffed? or the whole fuel pump?
    I had the car re calibrated it has helped a little but the problem is still there
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Maybe a dented / impacted tank that has impacted the fuel pickup sitting at the bottom.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Fuel pump faulty or poor wiring connections (earth etc). Check with an Auto Electrician.
  1. fuel problem
    By brandon17 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2010, 07:38 AM
  2. Fuel / Fuel gauge problem
    By 2ndLook in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2009, 06:50 PM
  3. serious fuel problem
    By jason.8484 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-08-2009, 04:04 PM
  4. fuel problem
    By SICKTG in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2008, 01:37 AM
  5. vs fuel problem
    By danny1987 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2006, 05:26 PM
