Results 1 to 19 of 19
Thread: Automatic boot lid
    VZ SV6
    Jul 2010
    Mandurah
    Default Automatic boot lid
    hey guys thinking around at work to day cus was super bored woundt it be pretty nice if you press the boot release buttom on the keys and the boot will open slowly on it own
    i had a look after work at the gas stays holding it up jsut wondering if stronger one cant be found for people with heavyer boots lids for ex bike racks
    what are your thoughts
    IF YOU WANNA REV IT CHEV IT
    acarmody is online now Donati..Whoa Green
    VX Berlina
    Apr 2007
    I don't know about the VZs but on VT-VX you can get the stronger struts to suit the heavy Clubsport spoiler, maybe same?
    Ronald Reagan (1986)
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    yeap there are generally 2 gas struts available for commodore boots, 1 to suit spoiler and 1 to suit no spoiler, get a pair to suit spoiler.
    Before i removed my spoiler i replaced the struts for spoiler and it would just pop ajar, after the spoiler was removed it used to open right up on its own. they'll be in need of replacing soon.
    VZ SV6
    Nov 2010
    Where the cops are few & speed cameras are none QLD
    Just curious.......when you press the boot release button (standard vz sv6) should the boot lid just unlock and stay down basically like it's closed or should it actually rise up and open a little?
    (Mine stays down)
    Life Sucks? Well cry me a river, put on a helmet, build a bridge and get the f**k over it.
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    Quote Originally Posted by SinnieC View Post
    mine stays down, dunno bout other people
    Spoken by a true member of The Committee
    VX Berlina
    Apr 2007
    Mine stays down too.
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Mine stays down as well. The very first few pops after installing struts made for spoilers it went up about about 3/4s the way on its own. After a few goes it just stays down when you pop it, dont know if that has anything to do with my rear end being lower though usually the struts getting worked in.
    Bloody strong though, takes a bit to slam your boot shut lol.
    VZ SV6
    Jul 2010
    Mandurah
    yh well if there two ill have the strong ones on ther now then cuz i have a spoiler on the maybe adding another two to total 4 gass struts you rekon
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    the only proper solution is to find out (research) the current rated psi of the struts then ask a strut supplier/reseller if there is a stronger rated one with the same diamentions.
    i do remember that some suppliers can presurise them to suit your needs but it may cost you a little more. i cant remember the companys thou sorry.
    VZ SV6
    Jul 2010
    Mandurah
    another thought wat about two power wi ndo regulators set up on it
    VX Berlina
    Apr 2007
    Wouldn't have the torque to move the boot IMO.
    tivoom's Avatar
    tivoom is offline pimpin pizza wagon
    VR S2 Wagon
    Jan 2009
    newcastle
    you could alway try a wagon tailgate set a tailgate aint light it might just work
    VZ SV6
    Jul 2010
    Mandurah
    might look at gettin sumthing nuematic set up simply becasue if i get strongt gas struts it will be hader to close were as if it air i can open and close it
    tivoom's Avatar
    VR S2 Wagon
    Jan 2009
    newcastle
    fair point keeps as informed dont the new bmws ect have boots like the you press a button it fully opens then you press a button and it closes and locks
  15. #15
    VZ SV6
    Jul 2010
    Mandurah
    aumting like this right its good also got a button to clsoe wich is very good idea wen i get home from tafe today ill reserch on nuematic rams or hydralic rams to push n pull and i will alsoe try find an old window reg cuz they are pretty strong on monstor grare they used 4 of them to push a bed tray with 400kg on it
  16. #16
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    just remember if you put in a strut thats stronger than standard, the boot will seem heavier/ harder to close...
    you also run the risk of bending the mounting brackets..
    pneumatic wont work unless you plan on running a compressor... kinda silly just to open your boot imo
    to do the job right will be some big $$$, and not just a couple of hundred...
    one way to do it... have a timer thats started by a signal from the remote unlock, set to 5 seconds or so then after the 5 seconds the linear actuators operate to open the boot...
    (5 seconds or so to allow the boot unlock mechanism to work).
    then you would somehow have another button and receiver setup to tell the boot to close... you could use a seperate remote, like an aftermarket remote unlock setup to send the signal to open and close...
    SMC linear actuators are around $740 each from RS
    another way is to chuck in a decent spring
  17. #17
    VZ SV6
    Jul 2010
    Mandurah
    yh fair call i contacted a wrecker to day and scored 2 woking power window componets for 25bux ea ill look at using this i rekong two will be able to gear it up and if the gear ratio need to be working i can machine neew gears as that part of my job
  18. #18
    VX Berlina
    Apr 2007
    Bloody hell mate, your going to a lot of trouble for a self-opening/closing boot.
  19. #19
    VZ SV6
    Jul 2010
    Mandurah
    well if the windo regs wont do it i wont bother not worth it that much to me but if they work i got it for 50bux and it will be super kool n wat ill do is do a write up so other ppl can do it aswell
  1. Replies: 1
    Last Post: 29-08-2010, 07:16 AM
  2. VY S Pac Automatic Boot Release Mechanism Not Working..
    By christopherVYpaul in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-04-2010, 09:48 AM
  3. Automatic Probs
    By watson01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2006, 09:49 PM
  4. Automatic Windows on a vt
    By krazy_kitchen in forum Electrical Wiring / Questions
    Last Post: 24-06-2005, 04:25 PM
  5. VP automatic into VN series I
    By bad benny in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2005, 01:20 PM
