Results 1 to 3 of 3
Thread: 2005 vz commodore light blow in sunglass holder on roof
    vz commodore lumina
    Jan 2010
    sydney
    Default 2005 vz commodore light blow in sunglass holder on roof
    hey guys um i dont no whats with this 2005 vz commodore but it seems holden makes em soo hard to change things they put in, well my light in blown in the Roof Sunglass Holder Map Light thing, Does any1 no how to Get the bulb out i tired to unscrew it but it did not come off the roof, what do i need to do?
    '07 VZ Acclaim wagon.
    Sep 2010
    Mulgrave, VIC.
    It's in the owner's manual, but you need to pry it off gently with a small flat-blade screwdriver, and it pops off. But it's different between some of the different models of light, so check your manual first.
    Need a part number? PM me.
    Luke.
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    It should be done very gently to avoid breaking the tabs that hold the lens in place. I used a flat-blade jeweller's screwdriver to very, very slowly and carefully pop the lens off to change the driver's side globe. It's an easy operation, just that the fit is precise and so care and patience is needed. I am actually looking around for pure white globes rather than these yellowish things that are bog standard.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
  1. installing vz sunglass holder / map light into vy exec?
    By esca_ByDesign in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-07-2010, 04:45 PM
  2. [VIC] WTB - VY-VZ Sunglass holder/Map light
    By sxc_sound in forum Swap / Wanted to Buy / Trade
    Last Post: 15-06-2009, 07:46 PM
  3. Wiring instructions for front light/sunglass holder unit
    By Marks-VY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-03-2007, 12:51 PM
  4. Roof Console/Sunglass Holder in VX Acclaim
    By SIXAPPEAL in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2006, 10:05 PM
  5. Calais Int Light/sunglass Holder For A Vt Berlina
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-10-2005, 05:54 PM
Tags for this Thread
