Results 1 to 4 of 4
Thread: factory lpg setup
    VZ
    Oct 2008
    Default factory lpg setup
    guys, i know there are a few factory fitted lpg setups floating around, i just wanted to know if they are injected gas rather than the mixer setups?
    im thinking of buying a wagon in this form..anyone else own a duel fuel factory fitted vz?
    Feb 2007
    Injected - IMPCO / BRC Sequent 56 system.
    Injected CNG, LNG & LPG: The only way to go better!
    VZ
    Oct 2008
    Feb 2007
    The injectors are a little noisy and they're installed over the top of the engine, so I would say that you would need to consult your gas installer in order to be able to replace spark plugs and coils. Other than that, with a simple tune (again, consult your gas installer), you should get some good fuel economy figures and perhaps a little extra torque in the low to mid range. My advice is to find an installer who has a lot of experience with AEB gas injection ECUs, specifically the BRC Sequent systems.
  1. How to connect Vt acclaim Factory Steering wheel buttons to FACTORY STERO
    By logan79 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-11-2010, 01:57 PM
  2. Setup in vy ss ute
    By nstrawbr in forum Car Audio
    Last Post: 11-05-2010, 11:07 PM
  3. Vs ss setup
    By DvS_Ls1 in forum Car Audio
    Last Post: 30-11-2009, 10:03 PM
  4. HELP!.. Diagram or info on Factory Heater hoses setup?
    By smokin_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-06-2009, 12:04 AM
  5. VK Stock drum and disk setup to a VT disk setup
    By justinp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-02-2006, 09:37 PM
