Results 1 to 16 of 16
Thread: VZ ute fuel... WTF??
    VZ ute
    Nov 2010
    Bahrs scrub
    Default VZ ute fuel... WTF??
    Hey people, had VZ tray back ute for 4 weeks, 6cyl, cant get 400k's out of a tank and not floggin it?? (mainly highway driving), tried premium and not much better than E10, starts off saying 500k's to empty when full tanks and never gets close....help, suggestions, idea's, theories...
    VE SV6 II Ute
    Aug 2009
    Melbourne, Victoria
    My old man has a vz one tonner, similar fueled consumption or close to it, I think it's because of the diff ratio being geared to carry heavy loads and still effects fuel when not fully loaded. But yeah hopefully that sorta helps, if not hopefully someone has a better reason.
    Yo.
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    dont the utes have a software issue that says fuel is empty when its not? how many litres does it take to fill up when it says empty?
    Spoken by a true member of The Committee
    VZ ute
    Nov 2010
    Bahrs scrub
    May 2009
    Gold Coast
    VZ ute
    Nov 2010
    Bahrs scrub
    Cheers for that, I have found alot of different "opinions" to say the least but spoke to a dealership today and he said the ute has two sender units and one for high and one for low readings and he said one was shagged this should fix it, catch is tray has to be removed to get to it and also said recalibrating computer could help as well.
    One thing for sure is no one is real confident on a fix that seems a shite load of cars and utes have, frustrating problem for otherwise great ute, but will keep going with it till I get a fix......
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    If the dealer continues to use the word COULD when referring to work they intend doing that you WOULD have to pay for, tell him that any such work SHOULD be at THEIR exepnse if they can't be more positive in their analyse of the problem and a 'sure-fire' fix.
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    I understand this is a fairly old thread but i have to say. Don't use E10, its more corrosive, it may be less expensive, but uses as much more fuel as it saves in price. Even the E10 fuel pumps from fuel stations break down far more frequently than any others.
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    There is something like a 20% economy penalty with that E10 fuel, and many people do wise to avoid using it for long trips. That is to say you won't get as much distance from a tank of E10 as you might, say, from PULP 95 or 98 (which is a much hotter fuel).
    It's the fuel gauge calibration carried out through the dash e.g. Mode+Set functions etc.? Thought I came across this in my owner's book.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    VX S S/C & BA XR6T
    Feb 2009
    Quote Originally Posted by CRUSTIN View Post
    Utter diatribe that...
    VZ One Tonner V6
    Nov 2010
    Yep mate, my 2005 VZ 1 tonne shows 1/8 th of a tank (the last red line before empty) after about 400 km - but it never takes much over 50 litres which means it's close to having nearly 1/4 of a tank in 'reserve'.....
    It's annoying because I feel like I'm always filling up, but sometimes I push it a bit farther knowing I've still got a bit of fuel in the tank....
    VZS-Ute06
    Aug 2006
    Western Vic
    Cool
    I'm averaging 600Ks every tank of Optimax (70L)
    VZ-Rob
    98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
    BAM BAM 11's Avatar
    BAM BAM 11 is offline BAM BAM11
    vz one tonner
    Dec 2009
    Kangaroo Island
    Two hole mod on the airbox worked Quite well on my vz one tonner 3.5 ecotech and gave me slightly better fuel economy
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by BAM BAM 11 View Post
    firstly, the ecotec was a 3.8 and was from vs to vy, vz has the 3.6 alloytec
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
  15. #15
    VZ Sv6
    Oct 2010
    Penrith, NSW
    Mine does the same, on empty it only takes 38 litres to fill it up lol. Its annoying..
  16. #16
    VT SS 5.0
    Oct 2004
    Seaford, Melbourne
    Guys its just a software update from holden to fix your fuel gauge problems. They plug the tech 2 in and 5 minutes later your full gauge will be normal
  1. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  2. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  3. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  4. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  5. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
