Page 1 of 5 12345 LastLast
Results 1 to 25 of 113
Like Tree4Likes
Thread: How to fix the sticky indicator in a VZ Commodore (BCM)
    VZ Executive
    Aug 2006
    Wellington, NZ
    Default How to fix the sticky indicator in a VZ Commodore (BCM)
    As promised, here is my document on how to fix the sticky indicator in a vz commodore by replacing the relay in the BCM.
    I have successfully fixed my commodore by following these steps.
    This will hopefully save some people from paying hundreds of dollars for a bcm swap, when really, it's just a $10 part that needs to be changed in the bcm.
    Use at own risk.
    bcm vz indicator fix.zip
    Here's another link to the pdf version of it for those unable to open it due to the zip file.
    http://homepages.xnet.co.nz/~dolsen/...icator_fix.pdf
    Last edited by dolsen; 17-01-2011 at 07:45 PM. Reason: Changed zip file to hopefully allow more people to open it. Changed to no compression.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Great write up, Daniel. All i need to do is buy it.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    VZ Executive
    Aug 2006
    Wellington, NZ
    Thanks.
    Yeah, was a bit gutted that there didn't seem to be any detail on how to fix this when it started happening to me, but am glad that I was able to put the info there for people to use.
    Wasn't sure whether to put it in the electrical / how-to or vz section. I'm sure people will be able to search for it though.
    Torquative's Avatar
    Jun 2005
    removed - no point to my post!
    2005 VZ Commodore SV6
    Mar 2010
    Followed this guide to remove the sticky relay today, it was spot on and took me 40 minutes to remove, un-solder and put everything back together.
    I just removed it for now as i would rather have no hazzard lights and flashing indicators instead of the thing sticking everytime,
    im now waiting for a group buy
    Torquative's Avatar
    Jun 2005
    Got ya PM, ta!
    I'll look into it in January. Dont know if it'll make it cheaper or not but hey if we split the postage costs amongst a few people and we meet their minimum order cost then its worth it!
    Mar 2010
    VZ Executive
    Aug 2006
    Wellington, NZ
    Quote Originally Posted by 1FATVZ View Post
    sounds good, how much do these relays go for anyway?
    Well, I got mine for $20 NZD. That included $4.50 of postage, so, not too much.
    Torquative's Avatar
    Jun 2005
    better then the $900 replacement!
    I'm finding out now with them to get a batter idea. So far there's only myself and 1FATVZ whose after a relay!
    Mar 2010
    Quote Originally Posted by dolsen View Post
    awsome, is there anychance to get one individually or a smaller bunch soonish?
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    For those folk who are interested, I've got some relays on order as we speak, with delivery due the first or second week of December.
    The only real price killer will be postage, but I'm trying to find ways of minimising costs there.
    Mar 2010
    Quote Originally Posted by bcw61 View Post
    PM sent...
  15. #15
    Levick is offline Levick
    VZ Senator
    Mar 2009
    AKL New Zealand
    Can anyone assist with the supply of a suitable relay in New Zealand? Thanks in advance... Have turned the chirping horn function on and it driving the family nuts.
  16. #16
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    PM Sent.......
    The Blue One
    Quoted for truth
  17. #17
    JBDrifter's Avatar
    JBDrifter is offline Now in a Calais
    VZ Calais & VT Exec Wagon
    Oct 2006
    PM also sent....
  18. #18
    Sep 2009
    Even better news. I have finally received the relays. I have all three part numbers as used in the BCM, but the pic just shows some of the HFKM 012-SHST relays, which is the one causing the sticky indicator problem. I have also posted this in a later thread as well, so I hope the folder moderators don't get cranky with me.
    For those folk who have already contacted me, I'll PM you guys soon of specific details to get hold of some. For other folk, just PM me. I can't put any other details up lest the folder moderators get upset because it may be deemed a 'for sale' type post.
    Attached Thumbnails Attached Thumbnails How to fix the sticky indicator in a VZ Commodore (BCM)-relays.jpg
  19. #19
    Mar 2010
    received a couple relays from BCW61 today and successfully fixed the problem
    thanks to the awsome writeup, had it done in less than 30 minutes, excellent work by DOLSEN for the write up and BCW61 for sourcing the relays
  20. #20
    Sep 2009
    Glad that the problem is fixed 1FATVZ.
    Just to let folk know, I have more relays available for those who need them. Just PM me, and I'll give you the details.
  21. #21
    VZ Commodore Acclaim Wagon
    Dec 2010
    Tamworth
    Hi Dolsen.
    Having same problem and told it's a $800 solution. Can't unzip your file though - need your help.
    VZ Executive
    Aug 2006
    Wellington, NZ
    Quote Originally Posted by Scott P View Post
    Hi Dolsen.
    Have sent via email.
  23. #23
    VZ
    Nov 2010
    Received my relay today and problem fixed, special thanks to bcw61 for supply and going out of his way to send before xmas, also thanks to dolsen for his step by step instructions, thanks for taking the time to help.
    Cheers boys.
  24. #24
    VZ EXEC.
    Dec 2010
    VZ SV6
    Sep 2010
    bcw61 do you still have any relays left?
LinkBacks (?)
  1. 07-05-2012, 06:04 PM
  2. 07-05-2012, 06:02 PM
  3. 18-03-2012, 06:43 PM
  4. 05-01-2012, 11:27 AM
  5. 15-12-2011, 05:03 PM
  6. 23-10-2011, 10:30 PM
  7. 14-10-2011, 10:29 PM
  8. 18-09-2011, 08:43 PM
  9. 14-08-2011, 11:07 PM
  10. 08-07-2011, 11:28 AM
  11. 06-07-2011, 09:19 AM
  12. 25-06-2011, 06:21 PM
  13. 01-06-2011, 02:49 PM
  14. 09-04-2011, 02:27 PM
  15. 23-02-2011, 10:19 AM
  16. 20-02-2011, 07:36 AM
  17. 18-02-2011, 09:41 AM
  18. 14-01-2011, 01:47 PM
  19. 11-01-2011, 08:17 AM
  20. 29-11-2010, 03:25 PM
  1. VS Commodore Headlight and indicator Removal? How To?
    By slayer208 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2010, 02:19 PM
  2. VZ Commodore/Crewman Indicator/Cruise Stalk replacement
    By PaulP38A in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-03-2010, 03:32 AM
  3. vx commodore indicator relay
    By samoaair707 in forum Electrical Wiring / Questions
    Last Post: 20-01-2010, 08:34 PM
  4. vt commodore indicator problem! flashes when it feels like it
    By mrs.vr in forum Electrical Wiring / Questions
    Last Post: 08-03-2008, 09:57 PM
  5. sticky Ps
    By Tom04 in forum General
    Last Post: 16-11-2006, 03:34 PM
Tags for this Thread
