hey guys, i am in need of some new pads, and rotors need to be machined. however, the cost to get someone replace pads and machine rotor are more expensive than some slotted RDA rotors on ebay. just wondering what you guys think of these products, good or bad? worth the price? any help appreciated.
richard
HOLDEN VT-VZ RDA FULL SET DISC ROTORS *SLOTTED*+ PADS (eBay item 150515091131 end time 04-Dec-10 04:37:06 AEDST) : Cars, Bikes, Boats
RDA and DBA are the 2 of the top players in the brake market so the RDA's should be ok.
V8 brutes used to race on them , not sure if they still do.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
If you want the same as in that listing then I can do that package for $370 posted.
It's that easy mate..
Wheel off caliper off rotor off rotor on caliper on wheel on. Paint ur shit up while ur there
Life starts at 200km/h
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
It's worth noting that when changing the rotors you need to make sure the mating surface on the hub is clean of any rust and scale. Best bet is to get a set of wire wheels from Super Cheap and put them in a drill to clean up the surface to a shiny metal finish. The rotors may not run true if the hub surface is not cleaned.
Bit of emery paper does the same trick too.
thanks for all the help people. will take note to rid any rust while im putting them back on.
Using a rubber mallet is recommeneded when you are refitting the old rotors but if you replacing them with new rotors then any big hammer will do the job to remove the old rotors that may be rusted onto the mating surface.
Afterall you will be throwing the old rotors away so damaging them doesn't matter.
one more thing, if you still can't get the old rotor off, im not too sure if standard rotors have this, but my dads OEM DBA's had them, there might be 3 little holes on the rotor, just find a botl that screws into it, and the screw will press against the hub and take the rotor with the screw, as i said, dunno if genuine holden rotors have it, but on my parents vy acclaim that had standard DBA replacements in it, it did, cheers mate![]()
Bored or just wanna talk about cars? Add me on facebook and we can talk
http://www.facebook.com/#!/profile.php?id=1002697869
