Results 1 to 2 of 2
Thread: VZ Handbrake Light
    VZ Executive Wagon
    Nov 2010
    Mulgrave
    Default VZ Handbrake Light
    I have had one RACV guy come out that seemed like he knew jack shit. the light stays on - even when the handbrake's off - and i can drive still without a second thought/it feeling tight. FLuid checked out - so im thinking a wiring problem. Anyone shed some light on it?
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Quote Originally Posted by VZSILK View Post
    FYI, the park brake is purely an independent cable system (with completely separate brake shoes), that does not operate at all with the hydraulic service brakes.
    Are you sure it is the park brake warning light that is operating incorrectly, as I know that when the park brake is applied when the vehicle is moving, the chimes start going off? If so, then it could either be a faulty brake fluid level indicator switch or park brake switch, or a short to earth to the instrument cluster assembly, that is causing the fault, as they are both connected to the same point on the instrument cluster assembly. Try disconnecting the yellow/red (possibly brown/orange if vehicle has stability control) wire from each switch in turn, to help isolate the problem. Another possibility (although I imagine much less likely), is that the internal resistor connected across the brake fluid level indicator switch has shorted, which would give a similar indication.
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. VS Handbrake Warning Light and Sound
    By Piggers5 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2009, 08:49 PM
  3. handbrake light stays on
    By mundine in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2009, 06:02 AM
  4. Handbrake Light >???
    By Aussie_Watto in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-08-2005, 10:09 PM
  5. VN 91 Handbrake light
    By mwethereld in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-05-2005, 01:42 PM
