Sup.
As the title suggests, would a cat-back exhaust from a VX V8 wagon bolt up to a VZ (V6) wagon? I'm guessing it would fit as they're basically the same chassis, but I'm obviously not 100% certain on the differences such as cat and/or muffler locations and whatnot.
Thanks,
Luke.
Need a part number? PM me.
Luke.
If both are wagons and both have twin cats then yes they will interchange so the VX V8 catback will fit the VZ SV6 but the gains will be next to nothing as both systems are very similar.
You might be better off finding out if a VX/VY HSV Maloo exhaust will fit as this will have better flow while being louder but without being too loud than both of the systems you have mentioned.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
i know that ls1 exhaust will fit up to an sv6. how are the cats on the wagons? has it got 2 cats? if so, then it should be a direct bolt up
From memory, I do believe the VZ has twin cats.
I'm not looking for performance at all, mainly just give it a bit of a different note.
Thanks for the replies so far, guys. Keep 'em coming.
Luke.
if your not overly worried, may be cheaper to just remove the rear muffler
Better off going aftermarket then.
Standard systems are crap... That's putting it nicely.
