Results 1 to 11 of 11
Thread: Running problems on LPG
    VZ Executive
    Apr 2009
    Default Running problems on LPG
    Guys and girls, I have a VZ Exec sedan which is running on dual fuel (has a Sprint Gas system installed). While running on gas, it's started to develop some annoying (minor, I guess) problems. It's just had its first year service on the LPG system and just before I booked it in the gas system shut down and wouldn't run at all - the LEDs on the meter flashed at me and it beeped. The guys that serviced it reckoned it had a faulty mapping sensor or something which Sprint replaced under warranty.
    Soon after the gas service I noticed it would idle a little badly and when under load the engine would shudder and lose power like it was missing on a cylinder. It ran fine on petrol (I use 91 RON right now). I took it back and the guys replaced the spark plugs because they weren't done for some reason. That fixed THAT problem, but now it's still a bit crap.
    Even when the engine is warm it idles a little badly when on gas. I really notice it funnily enough when the aircon is on - the car will shake at the lights because the engine is idling roughly, and then when I take off it hesitates a bit before giving me any form of power more useful than a morris minor!
    Any ideas? Should I take it back to the gas guys again and complain?
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Quote Originally Posted by boxdog View Post
    Guys and girls, I have a VZ Exec sedan which is running on dual fuel (has a Sprint Gas system installed). While running on gas, it's started to develop some Any ideas? Should I take it back to the gas guys again and complain?
    YES - for goodness sake, TAKE IT BACK.
    Feb 2007
    Could be due to any number of different reasons. How many km's on your car? Could be a dead coil or two (remember that ignition components that are just 'acceptable' for petrol will be unsuitable for gas) or a calibration issue.
    Injected CNG, LNG & LPG: The only way to go better!
    VZ Executive
    Apr 2009
    Hey, well I took it back to the service guys (Rhodes and Heron in VIC, they're really good) and Perry there plugged in the computer and had a look around. He is adamant that one or more of the coil packs are shot and recommended to replace the lot. At $110 each x 6 + $77 labour that's a pretty bloody expensive proposition!!!
    In the meantime he made the gas mix a bit more rich (150 up from I think 100 or 110) and it's made it even worse idling but now when I take off it doesn't seem to pause anymore.
    Do you really need 6 of them? Can you just replace the dead one? Sigh...
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    you can just buy one, just ask him to replace the faulty ones. or buy one yourself and swap it around the plugs til it runs fine
    Spoken by a true member of The Committee
    Feb 2007
    When one coil goes, it's wise to do all six of them. Once you do your plugs and/or coils, disconnect the battery for a bit to reset the ECU. Once you've done that, give the car a good run for 15min or so and you should have a pretty good base to work with for re-calibration of the system.
    We have a VZ SV6 running a Sprint Gas system installed in 2007 which has never missed a beat - but then again our installer has always been top-notch...
    VZ Executive
    Apr 2009
    With due respect..How is it wise to pay 6 times more than you need to when they're about $110 each?? Are they consumables ie. are they expected to fail on a regular basis?
    Feb 2007
    Yes, coils are a consumable item, particularly if you're running LPG. They should last 150,000km-ish but there are no guarantees...
    JBDrifter's Avatar
    JBDrifter is offline Now in a Calais
    VZ Calais & VT Exec Wagon
    Oct 2006
    I've replaced two coils in the last year after having the exact same symptoms you have experienced. Replaced one the first time, and about three weeks later I started experiencing the issues again, so replaced another coil. Has been good now for at least the last 6 months. If it happens again though I'm just going to replace the whole ignition system (all 6 coils and plugs). It was a pain both times trying to find the problematic coil.
    VZ Executive
    Apr 2009
    Hmm. Are they hard to change over? It's a shame they're a "consumable". FYI the car is at 102k and I installed LPG about 87k. Recently had the spark plugs done in the LPG service too. It's only stuttering on take off now and idle - not during load, which is good, but yeah..I am tempted to give it a go and buy one to try changing it but wonder if it's worth the pain
    Feb 2007
    The coils are directly on top of each spark plug.
    There are also other things that may need attention at 100,000km including the combustion knock sensors and oxygen sensors, all of which tend to go at around that time and all of which have a significant impact on how well the engine runs.
LinkBacks (?)
  1. 5litre statesman with running problems
    By lippy88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2010, 08:49 PM
  2. vk problems blowing smoke running to ritch
    By dazz9 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-01-2010, 06:20 PM
  3. Running hot problems
    By Tom_1569 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2010, 11:56 PM
  4. running problems need help
    By scrabet in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2008, 05:07 PM
  5. '97 VT V6 running problems
    By VT_WA in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-12-2007, 01:34 AM
