Results 1 to 16 of 16
Thread: Best possible oil to use in alloytec v6 in summer temperatures ?
    05 vz s ute.
    Nov 2010
    newcastle
    Default Best possible oil to use in alloytec v6 in summer temperatures ?
    Hey all ive viewed this site for quite a few months as a geust and decided it was time i signed up. Im appreciate if any one could tell me the best possible oil that i could use in my alloytec itll be changed every 7500 ks and price isnt a problem im after best protection and performance for my engine in temps from 30-40 over summer thanks :-)
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Wondering why you're dumping the oil at 7,500km?? What sort of driving?
    In previous (old generation) V6 cars I never wavered from Penrite HPR 30 for long distance freeway/country driving. However, my understanding is that Alloytecs have specific oil requirements (Castrol Magnatec 10w/40 is widely used). That's all they put in mine last Friday from bulk service barrel. "Good for 12,000!", said the Techie.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    12000k's in the alloytec any you will be needing a new engine within 5yrs... heaps at the engine wreckers here from failing to maintain regular servicing...
    i do mine every 5-7500max
    i use pentire hpr 10 all year round...
    air temps dont change oil temps dramatically
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    Any grade oil, suited to your requirements will be fine, temp wise that is. Especially at that interval of changing you can get away with anything but the cheapest of the cheap. Even then it would be fine to use if you run diesel oil, the old school stuff not the stuff for modern diesels, to clean any of the junk it leaves in there every 20-50,000kms.
    Personally I do that with my Crewman, change oil every 10,000 km (I use very high quiality now but didnt always) then every 30,000 km I drop it and run diesel for 5,000 km and I dont have a single problem engine wise.
    The main thing you need to remember is not to let it get too old, stinks and is usually thick, because then it wont do its job. And always use the right weight for the conditions. In Darwin 10w/40 and 15w/40 is used fairly regularly, not entirely sure about the rest of Australia but if I remember correctly its used almost Australia-wide during summers.
    Hope that will help you.
    2006 VZ ute
    Sep 2010
    i use Nulon Fast flowing syn 10W40 and service it every 5000ks. any more than 10000ks and the eng will start to sludge up. Also id recomend that you use a synthetic oil.
    VZ Lumina..... VEII Equipe Sportswagon
    Nov 2010
    South Oz
    I use Penrite Everyday Full Synthetic 5W-50, good in my region where temps in summer can go in the mid 40’s.
    The same oil also comes in a 10W-40 grade.
    As mentioned Nulon make a fine product too.
    Penrite & Nulon (both companies are Australian owned and made) have a technical assistance contact numbers on their websites, as do with all oil companies.
    They’re very good at helping with more specific applications for your needs.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    everyone's going to have their own opinions, their own brands they stick too for various reasons
    But yeh nothing wrong with 7500kays. I do mine every 5 000 kays now. Dont need to but why not!
    05 vz s ute.
    Nov 2010
    newcastle
    Thanks guys for all ur help id heard alot of good things about the nulon full synth 10-40 also been told that castrol edge 5-30 goes great wat are ur opinions on edge? Also i assume ur talking about the old school high detergent diesel oils? Id love to give that a try what diesel oils would be best to use as ivr only heard bad things bout using injector cleaner etc to clean engine.
    Oct 2010
    Darwin, NT
    Basically anything, if your worried go into a car shop, ie autobarn or supercheap and ask for diesel oil that wont poison a catalytic convertor. That is the only real concern with it.
    It doesnt need to be overly expensive oil for it. I can try find what I usually use if you want, but I know my friend uses the repco brand stuff and his runs almost as good as my car (main reason it doesnt is he cant drive well at all and has caused a few problems of his own).
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    For average driving (for which the Commodore was designed)stick with the recommendations by Holden as found in the Owner's Handbook. You won't go wrong. Holden does not make any specific recommendation for chnaging oil specifications during hot weather/summer months.
    '07 VZ Acclaim wagon.
    Sep 2010
    Mulgrave, VIC.
    Quote Originally Posted by azazeldeath View Post
    The new range of Repco oils in the silver bottles are all made by Penrite
    Need a part number? PM me.
    Luke.
    Dec 2009
    With diesel oils it's also the amount or detergent in the oil and the ash content. Some diesel oils are not recommended for petrol engines unless they run on gas. For example I have some Valvolene Super Diesel here and I rang them up and it's not recommended for my Ecotech, reason is it has to much detergent and sometimes loosening sludge, deposits etc can increase oil consumption and get stuck in oil galleries, pickup filters etc.
    Oct 2010
    Darwin, NT
    That is true, but if you run the oil regularly then there will be alot less buildup of sludge. Also if you dont clean it, either with flushing oil or diesel oil then the galleries can eventually get buildups of sludge.
    When it comes to cars there is no perfect solution really, if you wanted a motor to run near 100% all the time you could always buy 2 motors and rebuild one every month and run the other. But that is a rather costly way to do it, not to mention labor intensive.
    The end of the day you need to decide whats the best for your budget, mechanical knowledge and your lifestyle.
    VP Executive & VZ Adventra V6
    Sep 2006
    With the Alloytech's (I have a 190kW engine as found in the Adventra) would you run an oil flush first and if so, which one is the best to use?
  15. #15
    Oct 2010
    Darwin, NT
    If you have the time then an oil flush then diesel oil would keep it in fairly good condition for alot longer. Any of the oil designed for flushing is good really. The hard part is actually finding it and using it correctly, main thing to remember is NOT to drive it you dont want to put load on the engine when its in there.
    Im sure someone on here has a detailed guide for using engine flushing oil.
  16. #16
    Nov 2010
    South Oz
    The site ‘Car Bibles’ has some good info and pointers for most.
    Not a bad write up in here about what you want to know.
    You could also try Mainlube.
    The company that maintains our Heavy Plant & Earthmoving equipment use their gear for flushing, and they tell me it’s pretty good.
    They do have a detailed guide on its use at the website, but it’s best to contact Mainlube before considering using it.
  1. summer
    By acex1138 in forum The Pub
    Last Post: 16-11-2010, 12:56 PM
  2. [VIC] Summer clean out
    By BT1-355 in forum Parts And Other Items For Sale
    Last Post: 17-12-2009, 09:43 PM
  3. Replies: 61
    Last Post: 20-11-2009, 04:09 PM
  4. New toy for summer!!!
    By HoldrodeoLT in forum The Pub
    Last Post: 28-10-2009, 07:27 PM
  5. High Temperatures
    By tr3nt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2005, 08:25 PM
