Results 1 to 2 of 2
Thread: l76 warm up and idle
    callum_88's Avatar
    callum_88 is offline Donating Member
    VT Exec 5 spd/ VZ SS 6 spd 6ltr
    Nov 2008
    Salisbury Downs, SA
    Default l76 warm up and idle
    not sure if i should be worried, had a look to see if anyone had the same prob in the forum couldnt find anything.
    just after starting my vz ss (l76 6spd model) i put my foot on the accelerator to a certain position when leaving, the revs will go up and the car would set off as normal but then the revs would cut out for a split second and then go back to the correct revs (like there is a fuel delivery issue or something) but this only happens when just warming up, this is annoying as i look like i cant drive for sh## when it cuts out but is fine after warmed up. (happens maybe twice in a row and not continuous). someone told me its normal as its a larger engine, but i havent heard any issues from anyone else.
    although idle is a little rough regardless if its warmed up or not and may go down maybe a couple hundred revs every 6 seconds approx if i remember right.
    due for a service soon, but its done it ever since ive had it, which is about 3 or 4 months.
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Might be the o2 sensors starting to give up.
    Have alook at the TPS as well.
LinkBacks (?)
  1. 29-10-2011, 04:07 PM
  1. E2 R8 6.2L rough idle when warm
    By Darren in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-04-2011, 10:42 PM
  2. VL Stalling on warm idle
    By kirsty_y81 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-03-2010, 09:07 PM
  3. Horrible idle when warm
    By justice4all3000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2010, 01:09 PM
  4. Missing at idle (when warm?)
    By M-Leach in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2008, 10:13 PM
  5. Rough idle when warm
    By Motorsport in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-11-2005, 01:55 AM
