Results 1 to 20 of 20
Thread: Minor Car Service - What do you expect
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Default Minor Car Service - What do you expect
    I dropped my car off for a service today at Carline Enoggera for the basic once over, Oil Change and the rest. We are driving to townsville soon, so fresh oil wont hurt.
    Now i know you pay for what you get, we paid $60 per car for two minor services and a bunch of other inspections/labour free replacements that come with it. Im about to pick the car up and know to expect nothing else done, door hinges greased, handbrake tightened, wheels rotated, change the windscreen wipers and that other usual poop you do on a hungover sunday morning. well that's what i expect from a minor service, best service i ever got was from Aspley Holden, but i paid for it.
    What do you expect from a routine minor service? what are your experiences?
    Life starts at 200km/h
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    to me a minor service is oil,filter,maybe other fluids topped up and a quick inspection over the car incase anything will need replacing soon or is already stuffed.
    as for experiences, i took my vy in for a free minor service the other day and all they did was oil and filter, then gave me a list of about 10 things that needed doing to the car which i basically new about anyway. i think thats the only time ive actually ever have gotten a service instead of doing it myself.
    GSXR1000
    Apr 2010
    WA
    These days in my experience, even with bikes, you literally have to tell them exactly what you want done, or it wont happen.
    There was only once when I got a mobile bike mechanic to come out and he did all sorts of stuff, it was a major service, but he did a whole bunch of things I didn't even think about.
    VZ SV6
    Oct 2008
    Newcastle NSW
    Quote Originally Posted by Mirkz View Post
    I know what you mean.... IMO, they should be checking for things like radiator hoses getting old/worn out, and certainly a quick test drive (transmission about to fail? bad need of wheel alignment?) that some car owners may not pick up on.....
    Some mechanics are certainly more thorough... for eg, my brother dropped off his old Camira for a rear wheel bearing to be replaced, yet the mechanic mentioned he topped up the engine oil as it was getting low, and wrote on the invoice that the front brake pads were getting low and a slight coolant leak... so there you go.... yet others will undo the sump plug, drain the oil, replace the plug, fill the oil up then get you out of there....
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    When we/I do a minor service, it consists of:
    Oil & Oil filter change (we always replace the sump plug washer at every service)
    Check/Top up fluid levels e.g battery, brake fluid, coolant, water washers etc..
    Check wipers & blades (replace if required at extra cost)
    General checkover, tyres, brakes, suspension, exhaust, radiator & coolant hoses etc.
    Check/adjust tyre pressures
    Check all lights are working (replace globes if required at extra cost)
    Remove & clean air filter element.
    Note down anything that requires attention (or ring the customer and ask if they want it done if it's something we can do on the spot).
    D22 St-r Navara
    Dec 2010
    perth
    and dont be surprised if a mechanic didnt work on it more than likely an apprentice
    Jun 2005
    Quote Originally Posted by Krisp View Post
    Thats not always the case mate. Anyway, that's how apprentices learn, by working on cars....If the apprentice is supervised by a qualified mechanic (as they're supposed to be), what's the problem?
    D22 St-r Navara
    Dec 2010
    perth
    apprentices arent supervised 24/7
    Jun 2005
    No they're not supervised "24/7" they go home after work, they don't work 24 hours a day
    Jokes aside though I'll ask again, what's wrong with apprentices working on cars? Or do you live in the stone age where apprentices push brooms and that's it?
    D22 St-r Navara
    Dec 2010
    perth
    whats with the attitude? maybe you have never had a bad experience from an apprentice working on your car? rather they pushed the broom instead of me.
    Jun 2005
    No attitude, i just don't see what the point of this post was?
    Fact of the matter is, apprentices are going to work on cars, end of story. Because if they don't work on cars and only push a broom for the first 3 years of their apprenticeship, what sort of tradesman do you think they'll be? No, I've never had a bad experience with an apprentice working on my car, because I'm the mechanic teaching the apprentice. I work on my cars, no one else
    D22 St-r Navara
    Dec 2010
    perth
    on that note there isnt many decent tradies out there either. the courses are made to pass ,the country is getting flooded with useless imports .There is nothing wrong with them pushing a broom, teaches them cleanliness in their work area.
    Jun 2005
    I'm not going to push the issue anymore, but 1 thing, the reason why there is a lack of good tradesman out there is because apprentices don't get given a chance to work. They push brooms and never learn anything, real catch 22.
    You obviously do everything yourself i take it? Sounds like no one would be good enough to do work for you. Anyway, this is all way off topic, so I'll leave it there.
    vz exe.
    Nov 2010
    Vic.
    I would expect at least what you paid for as listed on your receipt.
    I have learned the hard way if you want something done properly, you have to do it yourself! My last "service" included oil & filter change. They didn't change the filter. How I know this because I did the next change and had to use a breaker bar to remove the top off the filter canister. The filter was nearly black, but the sump oil was several shades lighter!
  15. #15
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    That is so true, when I was an apprentic I was normally put onto minor services and rebuilds (long story short I could do the job). But I will say and I know that this sounds cocky but I seemed to pay more attention to the rest of the job then the fully qualified mechanics. I was eager to check out the rest of the car so I could learn, if I saw something was wrong I put it in the notes. I normally did 2-3 pages of notes per service.
  16. #16
    D22 St-r Navara
    Dec 2010
    perth
    Quote Originally Posted by azazeldeath View Post
    Thats unusual, a young fella taking pride in their work. keep it up
  17. #17
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    How is it unusual? I see plenty of young people who take pride in their work day in day out. Maybe get up and walk away from ACA/TT and witness something for yourself instead of making useless comments.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  18. #18
    Jun 2005
    Quote Originally Posted by SabbathSS View Post
    Totally agree.
  19. #19
    VX S S/C & BA XR6T
    Feb 2009
    Classic lol,that gave me a good laugh cheers.Somewhat true really.
  20. #20
    D22 St-r Navara
    Dec 2010
    perth
    was working with a couple if indians over the years. one thought it was common practise to use my new geared spanners as a hammer. the other was just a nut and bolt fitter, if it didnt have either he was stumped. on a note to everything else said, if a grumpy old fart that hates his life
  1. Minor Service Checklist?
    By Bizmark in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2010, 10:00 PM
  2. VZ S Ute - What to expect?
    By Lemon in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-05-2006, 08:37 PM
  3. rear main seal, left engine mount,valley cover gasket,minor service $900is that good
    By eagle13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-12-2005, 10:31 PM
  4. What can I expect?
    By vick58 in forum General
    Last Post: 04-02-2005, 11:57 PM
  5. Car Service (Major or Minor?)
    By Thanh Ha in forum General
    Last Post: 12-12-2004, 12:00 AM
