Results 1 to 3 of 3
Thread: Monaro Pedals on a VZ
    VT V6 Executive Manual
    Oct 2009
    QLD, Molendinar
    Default Monaro Pedals on a VZ
    Hi Guys,
    I have a VT and I put the Monaro pedals on there and it looks tops, so I bought my brother the Auto ones for chrissy I’ve had a 2second look at his accel pedal and I notice the shaft is different so I want to know how I would go about installing the pedal onto his car. It’s a VZ Calais. Brake and foot rest are a 10 second job no worries there just the accelerator pedal I have a spare shaft off my old car (VS) if need be.
    VZ SV6
    Oct 2008
    Newcastle NSW
    The accelerator on a VZ is completely different to previous models as it is an electronic one, ie. no cable, it has a sensor to tell the computer how far down you've pressed it, therefore you need the specific VZ one like here :
    GENUINE VZ HSV/HBD FLY BY WIRE ALLOY PEDAL SUIT V-6 (eBay item 260702399209 end time 02-Jan-11 20:19:52 AEDST) : Cars, Bikes, Boats
    Phyco's Avatar
    Phyco is offline Alloytec and Proud
    06 VZ Acclaim Sedan
    Mar 2009
    WA
    Quote Originally Posted by Scroopy View Post
    The actual installation of the pedal can be quite difficult, and requires you to almost dislocate your wrist lol... There are two bolts holding the throttle assembly in at the top, basically they both need to be undone, and the sensor connection needs to be unclipped. Then it sorta just slides up, and you can slide the new throttle assembly (with alloy pedal) into place (Then re-insert and tighten the bolts accordingly).
    -My VZ Acclaim- feat. ASR Audio Sound/Lighting and Various Other Mods
  1. Pedals
    By Chris92 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-05-2010, 09:15 AM
  2. Replies: 3
    Last Post: 04-07-2009, 01:48 PM
  3. Vy monaro pedals
    By sp001in in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-10-2008, 10:12 AM
  4. Installing Monaro/HSV/Commodore Racing Pedals
    By kipela in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-07-2006, 08:58 PM
