Results 1 to 8 of 8
Thread: A lonely, locked up vz
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Default A lonely, locked up vz
    gabby is going around oz next year for 6 months by 4WD+campa. his vz (the "go~kart") will be sitting in the garage untended over that time. do you bright sparks have an idea if the car engine is ok left idle for that long or should it be used like idled now and then, if not run about? the technical man at the dealer doesn't have an answer! (nor does gabby; he is on chrissy leave to byron bay then 1770 beach).
    thanx
    --AnnaD--
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    If it is going to be left idle or unattended, then I would consider doing the following:
    1. An oil change, and run the fresh oil through the engine (just in case the old oil is dirty or has acidic residue).
    2. Remove the battery & leave it on a float charger if possible.
    3. Consider draining the fuel tank as well, as the fuel may possibly tend to go off in the 6 month period.
    Just my thoughts. Other folk may have different ideas.
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    What bcw61 said is pretty spot on, personally id find someone to take it for a run atleast once a week though keep it all running smooth. But aslong as it has clean oil some moisture absorbing material in the car chocks under the wheels and left out of park/gear and the handbrake off also helps.
    Final thing, clean the car, wax it and throw a cover on it and it will remain as good as new.
    VY executive
    Oct 2008
    One of my dads friends moved to England for two years for work but couldnt face selling his ve gts. So he has another close friend driving it to work once a week just to keep the fluids moving. You would damn have to trust that friend though...
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by bcw61 View Post
    This is what i would be doing... its the same procedure i use for the Jet Ski in the winter months
    Life starts at 200km/h
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    You can buy an additive for the fuel tank that prevents petrol from 'going off'. Probably available from a Marine/Outboard motor supplier or Auto Parts Store. All previous suggestions are appropriate however where you store it is also important. Somewhere dry with air circulation - otherwise rust could set-in.
    Aug 2010
    Speaking with Gabby this afternoon, it is his preference that car does get used occasionally (1,2 a week), but by who is tricky, as Gabb is not the trusting type on face value alone (he's had big trouble before loaning cameras to people). Car is always garaged (under studio) and secure; maybe the housesitter?? he recalled that the dealer said last week he could drive it around Aust. too! , if all options fail I think he will seriously consider that, with like a small camper-trailer (he has already ridden his bike around Australia in 1984-1986 which is why the guy's got wonky knees...).
    Thanx!
    --AnnaD--
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Car should be fine to leave. If i were you i'd be getting 4 jack stands and jacking the car up and placing it on the jack stands to get the wheels off the ground to prevent flat spots.
    Another benefit of this is, if you feel the need to want the car run up every so often, you can start the car and simulate driving if you so wish by running the car through the gears, that way, the car doesnt get driven on the street by a stranger.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  1. BCM Locked??
    By Darkk_Calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-08-2009, 08:26 PM
  2. locked vp HELP!
    By yggdrasil in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2008, 09:19 AM
  3. The Lonely Widow
    By sixshooter in forum Jokes/Humour
    Last Post: 07-01-2007, 12:12 PM
  4. I am lonely
    By buyAustralian in forum The Pub
    Last Post: 23-01-2006, 07:20 PM
