Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: oil filter Adaptor cap removal
    VZ SV6
    Dec 2009
    Sunshine Coast
    Default oil filter Adaptor cap removal
    Just wondering if someone could tell me whether to loosen the OIL FILTER ADAPTOR CAP is clockwise or anti-clockwise, there is an arrow pointing clockwise.
    I'm having trouble removing it.
    Any hints.
    thanks
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Anticlockwise to remove cap, clockwise to retighten (looking down from the top of the cap).
    It is only supposed to be torqued to 25 newton/metres. If you are having difficulty removing the cap, it is possible the cap threads were not lubricated last time it was refitted. If this is the case, then go carefully, as there may be a chance of picking up the threads on the cap or filter base (aluminium to aluminium threads have a tendency to gall).
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    yeah i cant get mine off, tight as all **** gonna go to the wreckers and replace the whole housing
    Life starts at 200km/h
    VZ SV6
    Dec 2009
    Sunshine Coast
    Quote Originally Posted by bcw61 View Post
    thanks. i'll keep at it..
    2006 VZ commodore Acclaim
    Jan 2007
    Ipswich QLD :(
    Had to use a breaker bar to get mine off... bloody tight ! But now its done back up to its correct NM
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    IMCRZY's Avatar
    IMCRZY is offline RESPECT!
    M6 Hazzard SV6
    Mar 2007
    Wollongong
    Quote Originally Posted by impulsive View Post
    i used a breaker bar, it broke my socket
    Iv seen em tight but never that tight lol....
    I WISH MY GRASS WAS EMO SO IT WOULD CUT ITSELF
    Jan 2007
    Ipswich QLD :(
    well they call em' a breaker bar for a reason.
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    Quote Originally Posted by VZ_commo91 View Post
    LOL what the
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    Tap around the housing and on top of the cap with a small to medium sized hammer. Apply torque to the cap in an anti-clockwise direction, while tapping the housing, increase the amount of torque slowly. If your really struggling with a breaker bar, there is something very wrong.
    VzVzVz's Avatar
    VZ S ute
    Jun 2009
    Port Melbourne
    Broke your socket? My sockets undo bloody truck callipers and head bolts no probs. Make sure not to buy the ones from Toys'R'us.
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    lol yea we tried to remove it from impulsives car on the weekend. no way its comming off ever haha. i didnt think something could ever be that tight. even the mechanic couldnt get it off!
    Spoken by a true member of The Committee
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    VT
    Apr 2005
    QLD
    we used the strut brace as a larger breaker bar, no joy
    WTF lol
    Hook a snatch strap and a landcruiser up to it
    or try a hydraulic spanner
  15. #15
    Jan 2007
    Ipswich QLD :(
    Quote Originally Posted by VT-565 View Post
    WTF lol
    Would probably break the landcruiser ! :P
  16. #16
    keeny's Avatar
    keeny is offline keeny
    vz calais alloytec 190
    Dec 2008
    Maitland, NSW
    had the same prob. first oil change on after i got my car i had to use a sidchrome bar and socket + a length of water pipe about 1.8m long over the end of the bar + 2 people trying to crack the prick. i suceeded. lol. now i dont have a torque wrench but have been able to do it up so that it doesnt leak while still being able to remove it again with just one hand on the socket every time since. dont people understand that its not holding up the harbour bridge and only needs to be nipped up?
  17. #17
    vz acclaim
    Jun 2006
    Mine took 2 people, a metre of pipe on the end of a 200mm breaker bar and sum skined knuckles but we got it
    TEAM CLOWN RACING
  18. #18
    05 VZ Berlina
    Mar 2010
    I swear some of them are tightened up with rattle guns!
    now : 05 VZ Berlina V6
    had : 97 VT Berlina V6
    before : 81 VH SL/E I6
  19. #19
    VzVzVz's Avatar
    VZ S ute
    Jun 2009
    Port Melbourne
    Its just the aluminium. When the engine heats up and cools down that many times, the threads lock together. Thats why it stresses in manuals and on the cap to only tighten it to 25nm. Taxis never have that problem because they're always at running temperature.
  20. #20
    Dec 2009
    Is there some sort of anti seize compound that can be applied to the threads? Loctite make about 4 differnet types.
  21. #21
    Ryley's Avatar
    Ryley is offline VZSV6
    VZ SV6
    Jun 2010
    Two Rocks/WA
    Uh, Wow.
    You use your strut brace as a breaker bar?
    If something is that tight maybe you should just get someone else to look at it :P
    Reppin' Alloytech 190/5 Speed Automatics.
  22. #22
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by Ryley View Post
    Uh, Wow.
    Why would i do that when i can fix it myself? I'd rather break it myself and save a lot of $$ than take it to a workshop and pay some ridiculous amount for someone to do what i will do anyway
    Besides.. the filter will be good for another 7500 km anyway
  23. #23
    Sep 2009
    Quote Originally Posted by wortus View Post
    The repair manual contains a specific 'CAUTION' stating the following:
    QUOTE: 'Lubrication must be applied to the threads of the oil filter cap prior to installation. Failure to lubricate the oil filter cap threads can hinder later removal and cause possible oil filter cap damage'. UNQUOTE
    From the sounds of things, they might be pretty much on the money with this caution, although it sounds like the description of 'hinder later removal' could be a minor understatement at the very least!!!
  24. #24
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    For future information. It would be fair to say that ALL threaded devices, fixtures, screws, bolts, nuts etc are undone by turning in an anti-clockwise direction (to the left). Having said that, the only exception that I'm aware of is that some vehicles, mostly commercial have a 'reverse thread' on the wheel nuts. That is they are undone by turning them clockwise - to the right.
  25. #25
    Dec 2009
    The pulley wheel on the belt tensioner on a Buick and Ecotech V6 is a left hand thread so it is undone by turning in a clockwise direction as is the left hand side pedal on a push bike and the hose on a BBQ gas cylinder.
  1. oil filter adaptor
    By v6 panelvan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2010, 08:59 AM
  2. oil filter adaptor
    Last Post: 27-09-2010, 09:05 PM
  3. [NSW] WTB: Stock Oil Filter Adaptor-VS V6
    By BoNeZ-01 in forum Swap / Wanted to Buy / Trade
    Last Post: 09-08-2010, 12:32 PM
  4. vt pod filter adaptor
    By pill in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-10-2008, 06:48 PM
  5. oil filter removal tool
    By fergi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-03-2005, 03:20 AM
Tags for this Thread
