Results 1 to 10 of 10
Thread: Manual gearbox issue
    04 VZ sv8
    Nov 2009
    Default Manual gearbox issue
    Hey guys I got a issue with my gearbox, when I sit in neutral with my foot off the clutch I can hear like my gearbox, sounds like a spinnig type sound, I don't know if it's the clutch or not and when I push the clutch in it stops making the noise, any input would be appreciated, cheers...
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    Can you feel any vibration when you hear the noise? If so, it could be the clutch is well overdue for replacement. If there's no vibration, the input shaft bearing could've gone. Show it to a mechanic and they'll give you the right advice, just not Ultra Tune, they're shit.
    04 VZ sv8
    Nov 2009
    Ah ok yeah I spoke some guys at a performance shop today and they reckon it's a common thing in these gearboxes but I will get them to check it when it goes in for a retune, I wouldn't be able to tell if there is any vibration cause my vz has been cammed so yeah the whole car vibrates lol
    VZ SV6
    Jul 2010
    04 VZ sv8
    Nov 2009
    VX S S/C & BA XR6T
    Feb 2009
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    i've heard with the v8 gearboxes when i was working at holden that straight outta the factory there wasn't enough preload put on the bearings through out the gearbox (don't ask which ones) which cause the load on the gearbox to twist abit and and put pressure partially sideways on the bearings and ruining the bearings after a while which may create this noise your hearing...not sure how true this is, but thats what i've been told by mechanics when i worked at holden...could be bearings..just throwing it out there
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    Bored or just wanna talk about cars? Add me on facebook and we can talk
    http://www.facebook.com/#!/profile.php?id=1002697869
    04 VZ sv8
    Nov 2009
    I had a mechanic at a performance shop have a listen to it today and they said it's a common thing with these gearboxes, he said even new VE commodore manual gearboxes make the same sound and there isn't nothing I should be worried about
    VzVzVz's Avatar
    VZ S ute
    Jun 2009
    Port Melbourne
    Quote Originally Posted by kngsv6 View Post
    ur vz has been cammed? nice. thats a first
    I'm sure it's a V8, along with the other cammed V8s out there.
    VZ SV6
    Jul 2010
    yeah my baad. some how i thought the op was talkin about a sv6. woopz
  1. 89 VN Gearbox issue
    By Sgt Santa Cruz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-02-2008, 07:32 PM
  2. vs ii gearbox or other issue
    By Garth in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2008, 11:11 AM
  3. Gearbox issue
    By mess666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2007, 08:09 PM
  4. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  5. Gearbox Issue!
    By Emackulation in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2006, 01:16 PM
