Results 1 to 2 of 2
Thread: Stuck Oil Filler Cap
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Default Stuck Oil Filler Cap
    Has anybody ever experienced an oil filler cap on an Alloytech that had signs of corrosion between it and the fitting where it screws in, with the cap so tight you couldn't remove it by hand? My friend has just encountered this problem in a car he is thinking of purchasing. The corrosion is the white powdery effect you get with alloys when they have been degreased and the degreaser has not been fully washed off.
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    It's a no from me .... must have used one helluva engine degreaser!
  1. primer filler
    By vxholden in forum General Discussion
    Last Post: 14-05-2010, 06:35 PM
  2. Water under the oil filler cap!
    By dazza33 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-07-2008, 06:44 PM
  3. Ute Fuel Filler Gasket
    By Struma in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2006, 12:35 PM
