Results 1 to 15 of 15
Thread: Best bulbs to get?
    VZ v6 Executive alloytech 04
    May 2010
    Default Best bulbs to get?
    what is the best lights to get for high and low beam? heard blue vision ones are good but then heard ultra white are better whats everyones thoughts from those who have em?
    cheers
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by HoldenOnn View Post
    Plenty of threads already on light bulbs, HIDs, etc. Do a search please.
    Why bother with this search crap... why bother posting at all, save your time and energy and go elsewhere...
    Life starts at 200km/h
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by glenny1988 View Post
    cheers
    Look into a HID Kit mate.. and get yourself some Projector headlights, the ones off an SS, very worthwile the lighting is awesome
    May 2010
    and HID kits illegal tho? thats the only reason why i ant looked at them heard they are illegal and cops my way are real anal and love picking anything that can get ya into shit!
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Why is it that there are so many people who want to make modifications to their vehicles without first checking the legallity. The only conclusion I can draw is that either they are ignorant as to their responsibilities regarding road safety of just too plain lazy to do some research. Yeah I know, ask on a forum, the 'texperts' will always give you good, sound and logical advice. (In your dreams !!).
    Something for you to consider:
    Motor vehicles have been required to comply with Australian Design Rules (ADR's) for lighting since October 1991. ADR 13 mandates the number and position of lamp assemblies, ADR 46 prescribes the photometric requirements of the lamp itself and ADR 51 is the standard for filament bulbs.
    ADR 51 accepts ECE regulation 37 as an alternative standard for filament bulbs and prescribes the dimensional and photometric requirements for filament bulbs (including headlamps). This ensures inter-changeability and correct functioning when installed in a complying lamp unit.
    All complying bulbs sold in Australia would be marked with the "E" mark and possibly the words "Suitable for European Use". The packaging may also indicate compliance with ADR 51 or ECE 37.
    When a replacement complying bulb of the correct type (for example H4 45/60 Watts) for a complying headlamp is fitted to that assembly, the light emitted will be within the spectral requirements for white light. This will not be in breach of Section 63 to Schedule 1 of the Transport Operations (Road Use Management- Vehicle Safety and Standards) Regulation 1999.
    Although these lamps are a standard fitment to many newer vehicles, a "blue" complying lamp can be fitted to a lamp assembly on a vehicle that was not originally fitted with these bulbs.
    It is important to note that ADR 51 limits the power of various bulb types, and bulbs of a similar style but higher power rating will not comply and should not be used. For example, the common H4 bulb that has a complying rating of 45/60 watts, is available in much higher rating of 45/100 watts. The higher powered bulbs produce more glare and the resulting light pattern would not comply with the ADR.
    Although regulations do not require drivers of pre-1991 vehicles to fit complying bulbs, consumers should be careful when fitting non-complying "blue" light bulbs to pre-ADR vehicles, as the resulting light spectrum may fall outside the standard for white light (that is, the blue frequencies may predominate).
    If a Licenced Examiner suspects that the light output from a headlight appears blue, the examiner should take appropriate action based on the following summary tables:
    For vehicles manufactured on or after 1 October 1991
    • Bulb must be marked.
    • Bulb must be the correct wattage.
    For vehicles manufactured prior to 1 October 1991
    • Bulb does not have to be marked.
    • Bulb may be alternative higher wattage.
    • Bulb must not show obvious blue light (when viewed directly ahead).
    Licenced Examiners Action:
    If, during the course of an inspection, Licenced Examiners have cause to inspect vehicles modified by changing the original lighting componentry assemblies, they are to ensure that individual vehicles comply with the previously mentioned details. Modifications of this type
    which do not comply with the above requirements are to be rejected immediately.
    May 2010
    for your information i have tried to do my research if i didnt then the bloody things would be in my car already hence why i jumpped on here and asked for other who have crossed this kinda of issue...so before ya start having a crack at me and all those who do their best to find out whether somethen is legal or not offer help and not critisism if thats the case dont say nothing at all...thanks for adding all that info on the otherside if ya just added that and not the first part then all would be sweet!
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    i agree with impulsive, get a good set of ss headlights, and fit a hid kit. as long as the beam is angled down and not a blue light, then you should not have any troubles from mr popo. but if you dont want to get hid, just get some narva ones from autobarn, they have a light demonstration at the counter with different bulbs which you can see and get an idea as to what they look like
    Spoken by a true member of The Committee
    May 2009
    Gold Coast
    Quote Originally Posted by Benboy View Post
    dude, you made a thread couple of years ago about HID, maybe you should have searched then and stop bitching now about 'legalities'
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Philips Xtreme are the best you can get in Aus at the moment I'm pretty sure. Also called Philips 80+ (80% visibility distance over standard headlights)
    I don't remember the name but there is also 100+ in a Philips bulb but I have only seen them being sold in Europe so far.
    Best RPG ever
    VZ Lumina..... VEII Equipe Sportswagon
    Nov 2010
    South Oz
    Gotta agree with the Philips X-treme Power +80%, we changed over to them on our works cars recently (Hilux, Triton,& Landcruiser) made a huge difference.
    Similar in performance to the Philips are Narva Blue Power (also +80%), which I’m running on my VZ they throw out out a much better light than standard and put a good deal more light down the road.
    The thing to take note is that both brands/models comply with legalities (ADR 51), and they’re UV safe which won’t stuff up your headlights... something to look out for with all globes.
    With those ultra white style globes there are two things about them.
    Firstly, many don’t comply with ADR 51....(taking note of your anal cops.)
    Secondly, they don’t have a very good lighting distance.... the set I bought (Philips Crystal Vision) had less lighting performance than standard globes.
    They were a lot whiter but, threw bugger all light down the road where you need it.
    If you live in the country like I do, best to avoid them.
    May 2009
    Gold Coast
    i think the problem i found with the higher kelvin rated bulbs are not at night, i found they work great (Narva Blue 6000K), but when it is raining, its almost like driving with no lights. appart from that, i would buy another set of them, they look great from the front too
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by richardpalinkas View Post
    hahaha SNAP..
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Don't worry about it mate, benboy posts that every single time he gets a chance to. I encourage you to leave rep points for his comments about you being ignorant.
  15. #15
    May 2010
    ant worried just dont need to be criticised for asking a lil help on a forum thats here for u to ask for help lol cheers mate
LinkBacks (?)
  1. 25-02-2011, 08:14 PM
  1. What Bulbs?
    By griffo04 in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-01-2011, 11:09 AM
  2. Headlight Bulbs...
    By Maci in forum The Pub
    Last Post: 27-05-2010, 02:48 AM
  3. green bulbs under driver side, passenger dash and centre console/rear bulbs
    By GMHCalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-10-2009, 01:12 PM
  4. new bulbs
    By Matty o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-05-2008, 10:03 PM
  5. Bustin' Bulbs...
    By Alan Shore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2006, 02:49 PM
